  • Replies 155
i got my car pc.. the thing is smaller then 3 cd cases put together.. looks hot.. too bad ram is not upgradable but 256mb ram should be ok for a cap pc.. il only use it for the net when i am away from home etc etc
will have it installed and setup this weekend once i can workout how to stuff the hdd into there
Is that one of the single-din pc setups?
I didn't want to go so small (mine is about the same size as my amp) as it wanted it to be semi-upgradable and have room for a capture card.. eventually I'd like to have some good quality cameras throughout the car :P
i see the anti-lag and rotary idle had them either running for cover or scratching their heads at Summernats.
http://www.vi-pec.com/forum/viewtopic.php?f=3&t=73
nice comment about it being all over the Power FC too.
we should have the engine monitor up and running soon for you to try with it also.
Edited by DiRTgarage
I worked out how to setup Group N Anti-Lag and Cycle idle at Summernats, gave it a good work out, here is a video of my car spooling up 20psi of boost with the clutch in then dropping it (just a little burnout i was not keen to get kicked out)
Watch old mate to the left, he copped the extream anti-lag pressure from the side pipe and was jumping outta the way :laugh:
*More Vids of Anti-Lag*
Uploading more atm
bloody yobbo's.
ahh paul you'd love it :laugh:
haha not really...only good thing about summernats are the pavillions + dyno.
glt toy....how much traction loss when launching anti lag etc???? is it very driveablewith the features + are they easy to turn off (rotary control, anti lag etc)
ahh paul you'd love it :(
Cycle idle is NOT anti lag, its for cooling when the car is on anti lag rundown, so when your not on anti lag the extra air and no spark in the cyl cools it down heaps, i noticed when idleing around with cycle idle the engine would not go to operating temp on a very hot day.. which is weird...
You can turn anti lag off with a digital input switch (but cycle idle stays on), and when my car is on 24psi with anti lag there is no such thing as traction what so ever. Its just a big show off thing i wreckon :( but its fun and grabs attention
its also kinda hard to drive the car with cycle idle.. its mainly for WOT driving so i will have it on again for power cruise.
Id be interested to see whether anyone has bothered to run the boost controller that comes with these computers. The guy whos retuning my car was part of the development team of these new ecu's and said they are incredibly good.
Wouldnt mind hearing some other opinions as naturally he is a tad bias!
Cheers
will let you know.. will be trying a stock r33 solinoid and the boost controll in the next couple of weeks.. hmmm i should do it tomorrow but i am lazy.
I'm using the boost control feature. I've got a Mac solenoid in place of the stock one. I have wired the ECU up to an external switch (factory fog light switch) for high/low boost :) The boost control seems to work fine. It's open loop though, which means it takes a little longer to tune on the dyno. It also has overboost protection.
There is a closed loop boost control feature coming soon I believe. I'm looking forward to that one.
this is prolly going to get laffed at, but since the vipec is just a board that you put in ur standard ecu is there a way to put it in your PFC and thats a way of possibly retaining the hand controller without having to go laptop..
No not possible at all.. however in a few weeks there will be a Vipec Dash available which will run rings around the Crappy padel power fc hand controller and have programable shift lights and all kinds of stuff available.
I will do a review on the Dash just before its about to be released.
Sounds great. I have an overboost problem at present and wouldnt mind checking out whether its teh boost controller thats causing the problems without buying an expensive new one. Solinoids are 100NZD (not sure about AUD) if you want a new one also.
Look forward to hearing how it goes mate.
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
