Hi
i got very nice Rx7 Rz for sale
was plan to keep for myself. but i decide continue my race Rx7 project.
so Rx7 Rz is up for sale
even rare than Spirit-R Type-A
2000
Pearl white
38000km
Recaro Race seat (factory Rz spec)
Exhaust system
other is full stock car
Light weight spec(factory Rz spec)
4.3 Diff gear (factory Rz spec)
BBS 17 inch wheel (factory Rz spec)
Price is $43000 ONO
For sale: Mazda Rx7 Rz 2000
Item Condition: very good condition
Price and price conditions: $43000 ONO
Extra Info: Stock std car. 1/175 Mazda every made
  • 5 months later...
  • 1 month later...
please send me your email
i will send you some pictures
cheers
hi sorry to answer so long time later. I don t have enough post to send you my Email by MP. Send me yours by MP and i m gonna write to you when i get it. Thanks. Cheers
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
