hey indicators are the easiest ever all you have to do is pull them back and they clip out. have a look at the ones you are putting in i am pretty sure you pull them to the rear. by pull i dont mean out towards you but slide rather to the rear of the car it comresses the clip holding them in and they just pull out towards you once you have them back far enough
good luck
:| mine are stuck solid to the guard. I bought nismo clear ones and they seem to just have a round circle... I just tried for 10mins on what you said, sliding them towards the rear and nothing happened lol, they are stuck like superglue :P
Edited by Ten Four
there is a screwed on clip that clamps the light to the guard, im pretty sure you can get to them with a stubby screw driver after taking your wheel off - also the plastic inner guard.
Just be very very careful when you do it. Even if you don't want to keep the originals you can always sell them.
But yeah, they should should slide back just a fraction, enough to get a flat head under there to undo the clip.
^dreamr33 i got them on ebay, the genuine ones inc bulbs for about $61 delivered. (replicas about 45 delivered) Didn't get round to doing it today, will try tomorrow..... went around the outside of the car with armourall :D
Edited by Ten Four
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
