for the local ppl of sydney there was the supernats event held at eastern creek yesterday, i didnt go but hav heard it was pretty good. wat worries me is the setup the cop/rta/epa had there. friend of mine got done for speeding, noisy zorst, leaking power steering and horn not working, total $450 fine. and he reckons he was 1 of the lucky ones there compared to the other cars waiting to be inspected.
apparently there was about 4 or 5 test stations there which once ur pulled over u hav to go through, and at a event like that, wat kind of cars and fans wud u expect to rock up...mmmm. it was a feeding frenzy for the cops. did anyone get caught up in this mess ??
i kno cops cant do a RBT within a certain distance of pubs, so duz a similar rule apply in this instance ?? probably not.
don't wanna go into detail but my car is full of defects !!! so wat is there left for enthusiusts like us ???
https://www.sau.com.au/forums/topic/24933-concerning-thoughts/
buy a bicycle and let the goverment suffer from not having any defects/speeding fines!
now that would stuff them all up
but hopefully this country changes before something that drastic needs to happen
i hope
Originally posted by 2fardown
Fix the defects or be prepared to get a fine.  Quite simple really.
Thats right... simple.
If the cops think they can outsmart all the car enthusiasts by seting up these "test stations" outside car events (of all places), then outsmart them by making sure your car is tip-top... or don`t go to the event in a defective car.
I can assure you all that there is absolutely nothing more satisfying than having your car gone over by the transport dept. and the cops...3 time and still they find nothing...the whole time I just sat against the front guard talking on my phone and occasionally asked "have you lot finished wasting my time" the best feeling I gaurantee :) Yes it cost to get it right but it is worth every cent.
i understand the idea of fixing defects so u dont get fined for them but my point is who sets these rules ???
ever seen a engineer try to put sumthing togetha on paper but the technician laughs at the idea in practice (no offence to engineers)
ever seen tech books where the typist types stuff down he/she doesnt know about and makes mistake (no offence to typist)
surely sum1 can agree that some of the rules are really silly and not practical ???
end of the day i do realise rules are rules and u gotta follow them so i dont need ppl telling me that but i am just after sum thoughts of others about this issue
The problem with mods is that there is one rule for all cars for example they say that it is against the law to lower a car more than 100mm from the ground unless it is like that as standard now for a lot of cars you can easilly go beyond 100mm and still drive it like my mates old EK Civic which was defected at 45mm off the deck...you could still turn lock to lock without interfearence and the suspension could still travel without bottoming out yet it was still "Illegal" Unless there was a rule for every single different car on the market then we have to either do the right thing of hope not to get caught...the later is the option I normally choose and have done well in my years of driving modded cars, the key is to not take your car where there is a likelyhood of you being pulled by the cops...like at a "Car event"
I remember leaving last years Jamboree in QLD in my line with NO exhaust apart from my 4" dump and front pipe...it was way loud and there was a cop parked just after the entrance, I remember thinking "Dam here we go" now it would have been my fault if I had been caught...lucky I had enough speed up to just coast past him and down the road...but I would have had no one to blame had I been caught....
On a side note :) Don't try driving like this for more than a few minutes, it was a 70 minute drive home at 10pm, by the time I got home my head was thumping :) Sounded sweet though.
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
