Im under the impression that carbon fibre bonnets are way to strong and are not subjected to crash testing like the standard bonnet therefore would just penetrate into the cabin and cut your head off.
Not sure about fibreglass coated with carbon which will crumple but is very sharp and jagged when you break it e.g a fishing rod.
Wings can be illegal too because they can be a risk to pedestrians. Alot of people i know got defective VN for T-wings and had to remove them.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4324054
If carbon bonnets cut your head off there wouldn't be a single manufacturer on the planet that would create cars with carbon bonnets. Seeing as cars from factory tuning shops can come with carbon bonnets I don't think that would be an issue.
Having said that, I'd lead to believe that carbon bonnets shatter into many shards upon impact which can be a health hazard to pedestrians and other road users as well as the occupants of the car.
I've had a carbon bonnet (fibreglass core though) for a year now and have driven past many a cop car and been through several booze bus set ups and not a sinle cop said anything. Does that mean its not defectable? Probably not. I think it means if you drive sensibly and your car isn't over the top the average cop won't give you any headaches.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4324241
if it hasn't been crash tested for occupant/pedestrian safety as part of a New Australian vehicle, then it's defectible.
Come on guys, It's not that hard to figure that out.
here's a good place to start with our Vic rules:
Vicroads standards
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4324280
What Ronin says is right, if it hasn't been ADR approved it's illegal. Even though non-standard stuff may be just as safe, safer, or better than stock the fact that it hasn't gone through all the tests means it cannot be placed on your car.
It's the reason some cars aren't imported into here (or at excessive cost) because manufacturers can't justify the high cost of compliance for a high volume import.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4324323
im located in NSW
as you can see in my profile if it shows thats the car, im not to sure exactly what type it is and stuff and i was thinking of maybe still getting engineers certificate for them both just to be safe but yeah im not sure.
yes, clearly the link I posted is for Vicroads.
How about you use a search engine such as "google" and find RTA for their regs?
If you can drive a computer to find SAU, you can find *and read* the RTA rules and regulations yourself.
sorry if that sounds harsh, but so many people come to SAU and ask questions that can be researched independently on the internet (in terms of legislation, rules and regs) and get hearsay and rumour based answers such as "my cousin's mate got done by some piggaz for his coolerz and carbon so itz illegalz".
Get the info directly from the source.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4325127
I wish I had cf bonnet its like glass so yeah it would shatter if you crash, so I think to be safe I will stick to my normal bonnet lol.
But if it ever does become legal or if they bring out a safer option ill definately be thinking about getting one for my 32.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4325249
on the other hand, you might try putting in a vspec II nur bonnet...aren't they CF? Seems like that may be legal as it is allowed on Nur's.
of course noone will probably know it is CF because it is painted except for the NACA duct.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4325300
^^LOL!
If you know your GTR V-Spec II's, N1's and Nur's, they all came with stock Carbon Fibre bonnets with the NACA duct.
When ppl know that, they will know you gota Carbon Fibre bonnet.
So yeah thats an option.
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4325584
Gold star for you Marcus :D
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4325605
lol! mate your car has a CF bonnet from factory! So they must be subject to testing and be passed originally.. at least in Japan!
https://www.sau.com.au/forums/topic/249330-carbon-fibre/#findComment-4326559
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
