If You Could... Porsche Or Gtr
N/A®
 Share
For those who have never been to Tokyo, this is defintely a city for 911's. The ones who can afford them obsolutely love them and you can pretty much find them all day long.
A Porsche guy came into our office yesterday to pick up my bosses car for its 1st service informed us of something interesting. At his dealership alone, 5 of his customers traded in their 911 GT2's and GT3's for the new GTR. :/
After a few months, they all switched back. :/ When asked why, they said after you the thrill of the straightline accelaration and hype goes out, they prefer the Porsche which I can understand. He also mentioned that the new PDK transmissions are not that good.
Just thought I would share this with you guys.
Edited by N/A®
  • Replies 109
R35 GTR....It's faster and tougher without the wank factor......not only that there a lot of change to spend of even more go faster bit's. :/
Edited by Jetwreck
Im sure thats what the Porsche owners are saying as well. Personally I have owned many Nissan models including GTR although not the 35 and would probably go 911 as well. I mean just look at that front end and the built is so much more better compared to the Nissan.
Reliability is the key. I think we all know that 911’s can take redline punishment day after day and year after year and they just laugh right back at you! The question is can the GT-R handle this same kind of punishment and perform just as well? Only time will tell!
After a few months, they all switched back. :D When asked why, they said after you the thrill of the straightline accelaration and hype goes out, they prefer the Porsche which I can understand.
well obviously they prefer the porsche... otherwise they wouldnt go back to it. But, why do they prefer the porsche?
:D
Because Ive owned many Nissans including GTR, although not the 35 which I contemplated buying before getting my 6 series. Also I have easy access to the 35 here in Japan and my boss owns a Porsche.
The biggest 2 difference for me is the quality and at the end of the day knowing that its only a Nissan which anyone can buy. But thats is after living in Japan for 4 years. Unlike when I was in Australia, I see a GTR now and I dont even take much notice honestly. :D
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
