ha sau'ers
ive just recieved my cooler and piping in the mail but i want to go a more stealth look so i want to get the cooler and the piping sprayed black but im not sure on where to go i want a nice glossy black finish on them.
do i just take them to a panel beater or some that does powdercoating im not sure
help appreciated
thanks
julz
https://www.sau.com.au/forums/topic/249367-spraying-engine-parts/
hey mate just DIY it much cheaper and easier. if the piping is polished alloy which i assume it is give it a sand with some fine wet and dry sand paper then use wax and greese remover then primer then paint. depending on the primer you may need to give it another quick sand. and try and use good quality as i've found with paint / primer you really do get what you pay for also make sure the paint and primer is all heat resistant. hope this helps and good luck with it.
Edited by NSM033
yep spot on, hit it with some 600 grade paper, doesnt need to be wet rubbed.
if you get any nibs in the primer/sealer that are horrorible, get them with some 400-600 grade pape and give it a light scuff and go a dust coat or 2 before hurling it on for that nice flowing gloss finish.
you'd probably pay 40-50 bux per pipe section at a bodyworks.
facing the pipe back, primer sealer or light putty, then prep, clear over base or solid colour, either way it will get a bit pricey.
cheers
Edited by Mr. Untouchable
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
