you may be better getting it up on a hoist and have a welder handy as many of the dump pipes out there need a little tweeking to fit correctly. but if you know its going to fit then its not hard to attempt yourself, just do the usually exhaust things, spray a little WD40 or Inox on the bolts/nuts before removing them, and you may need to replace a gasket or two.
Edited by QWK32
+1 on an easy job. and yeah let the car cool down for a few hours AT LEAST after you have driven it.
just make sure you line everything up before you completely tighten the bolt/nuts up because youll just have to go loosen it again when it doesnt quite line up :P
............ i've got a stagea specific pipe ..........
hey briggsey,
Where'd u get the stagea specific Dump Pipe from/how much did it set u back??
cheers
Mattye
Edited by mattye
hey mattye, got the stagea dump/front from Just jap aye, settled for a JJR bell mouth so was only $200 i think was about $30 for postage, got a catco hi flow while i was at it awell. nice little chrissy present for myself :)
Edited by briggsey
hey mattye, got the stagea dump/front from Just jap aye, settled for a JJR bell mouth so was only $200 i think was about $30 for postage, got a catco hi flow while i was at it awell. nice little chrissy present for myself :laugh:
nice one mate...should sound pretty sweet.
c if u can post up a vid so we can hear how loud/quiet it is once its installed.
Its easy. Need an allen key for bellmouth bolts and an extra jack to hold the cat back section up. I could not get one of the allen head bolts in. It needed a bit ground off the head. It took about three hours, with stops for liquid sustenence.
I managed to do mine with one car ramp - drove the car up on the front passenger side wheel, chocked up the rears and worked from there. Safer than using a jack with stands. :laugh:
Bellmouth dumps are a snore to install, just make sure you've got plenty of arm stamina, a good ratchet set, grease, WD40 and good eyesight for lining everything up. When I was mating the dump to the cat I used bricks to take the weight of the cat-back section. :D
I managed to do mine with one car ramp - drove the car up on the front passenger side wheel, chocked up the rears and worked from there. Safer than using a jack with stands. :worship:
Bellmouth dumps are a snore to install, just make sure you've got plenty of arm stamina, a good ratchet set, grease, WD40 and good eyesight for lining everything up. When I was mating the dump to the cat I used bricks to take the weight of the cat-back section. :)
Did you get all the bolts in?
Just did a split-dump install on my series 2. I found it easiest to unbolt the dump pipe flange at the cat' and remove the turbo and dump as one unit... but that was because I was changing the turbo at the same time :) It was then pretty easy to bolt the dump to the turbo out of the car, and carefully re-insert the turbo & dump assembly from the engine bay.
Cat ended up angled down ever so SLIGHTLY and wouldn't quite mate with the first flange on the cat-back exhaust (at least not without putting more force on the dump to keep it straight than I was comfortable with). So I had an exhaust place make up a mild 3" cat-back system with mandrel bends and magnaflow oval mufflers :down: Very nice but very drony... loudest at 2k then it gets quieter???!
i did mine yesterday..... made me a little angry by the end of it but it was ok... start by getting rid of the heat sheild and drowning the bolts in inox... while there soaking take the cat out/off from the dump... slowly crack the bolts on the turbo... i was told to be carful as there obviously guna be fairly heat f**ked from there hard life.... i had trouble getting the 2 middle bolts in... theres like a rectangle shape that forms the bell mouth... and the 2 middle ones didnt go in very far on mine.. all in all i didnt notice alot of difference from having the 3" decat back, to adding the dump but ahwell
    • Swapped the injectors around and the misfire followed. I went ahead and ordered the Deatschwerks 550cc injectors and am currently waiting for them to be ship and arrive. In the meantime, I've had my Nistune soldered to the ECU. Tested it, and and tried it out with the software. Everything should be prepared for when the injectors arrive.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
