  • 3 months later...
Used to build my rigs, but just doesn't interest me like it used to, so now I run a couple OE machines:
HP 15s-eq Notebook 45W
- Ryzen5 5500U
- 2x8gb Corsair DDR4 3200
- 970 Evo Plus 1tb
HP Elitedesk 705 G4 35W
- Ryzen5 Pro 2400G
- 2x8gb Kingston DDR4 2666
- Kingston A2000 1tb
They're compact, low watt & game surprisingly well if you're not wanting more than 1080p.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
