Has anyone found a fix or attempted to fix the dodgy climate control display in the R32? Mine operates intermittently but much of the time parts of the display drop out or jumble. It seems to be worse with high cabin temperatures but can play up any time.
EDIT: Just thought I'd bring up this old thread of mine as I've got my climate control apart on the table right now and would like to know if anyone has fixed one successfully before and if so what did they find.
https://www.sau.com.au/forums/topic/24948-r32-climate-control/
I had this problem. Some buttons didn't want to work either. Pulled it open and cleaned all the contacts and switches and stuff with contact cleaner and cotton buds. Worked perfectly for about 2 weeks then the buttons went abit intermittent but she works most of the time. Display works fine though
mine has a tendancy to not come on when i start the car, btu give it 30seconds and it will appear and all the buttons / display works perfectly after that. this only happens occasionally.
my theory is a loss of charge overnight and a bad solder joint rendering it incapable of getting enough current initially when i start.
i dunno...
  • 5 months later...
my screen used to garble and drop out on the odd occasion but i think the whole lot shorted out. i turned the ac off and while the screen turned off what actually happened was the fan set itself to demist and i could not stop it. the next day when i turned the car on it set itself to demist again. what the??? after a couple of days it seemed to fix itself. i drove to work with the ac on - no problem. i turned the ac off before turning off the car - no problem. when i got back in the car 6 hours later the whole cabin smelt like burnt plastic. ive since pulled the fuse for the ac and the smell is gone but ive had no ac for a few weeks now. ive had a brief look behind the ac unit and all the wiring looks fine - no melted insulation. will try pulling the control unit apart and see if theres any burns in there. if there is how much would i expect to pay for a replacement? apparently the r33 unit is the same as the r32 unit. if this is true i will buy a 33 unit as its newer.
yeah mine also is a little tendancy to occationaly work then not work, often with a quick tap on the screen it works again......very stange, thou must be a loose connection somewhere. I'm going to have to pull the unit out and check the soldering. Also whats the deal with the button on it which when pressed shows some sort of Japanese writting and degrees? is that outside air temp or wot?
Bit off topic sorry but alot of the funtions also didn't work when i bought the car on the climate control but they guy gave me a pile of parts which he thought were the stock amps or something, a bit off lookin around i realised that one was the computer at the back of the car which seemed to fix both the HICAS and the climate control when i plugged it in.
The little Japanese writing says ambient i think, but you should be getting the temp as well. Perhaps the sensor is not working? Dont ask me where it is though, i dont know.
MM2death said:
Yeah mine has a few funny things with it.  First, a couple buttons don't always work.  Secondly, the ambient temp button used to display the actual ambient temp when i got the car, but now all i get when i press it is some Japanese writing.......  Any ideas?
Scott
I pulled the control unit apart to look for anything a bit sus like dry solder joints or dirty contacts. 3 screws and the face unclips. 2 more screws and the front circuit board pulls off.
It is connected to the rear circuit board by a row of pins that push through a socket in the front board. This connection might be where some of the problems are.
I took out the 2 screws at the back and pulled out the back CB (tight). It looked like it had been resoldered before so I tidied it up and put the thing back together. I ran it for a few minutes and it performed like new so far. Fingers crossed.
Just pulled mine apart last night. everything looks fine so maybe mine is a prob with the wiring. will take it to an auto elec after ive payed rego. will let y'all know what the problem is so maybe can save the rest of you some money if you ever have the same prob. just hope it dont cost too much.
I think the AMB sensor is on the top of the dash, left hand side, very close to the window. Well its some sort of sensor
Ambient sensor is at the front of the car on the factory thermo fan.
As for not working.
Done a FMIC lately?, and removed it maybe.
i found some useful stuff on the climate control on this article, i think it was around page 30- 33 (diagnostic mode for the climate control, very interesting) would probally help alot of u guys find the problem with urs.
www.vspec.btinternet.co.uk/Links_files/Diagnostics.pdf
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
