Has anyone found a fix or attempted to fix the dodgy climate control display in the R32? Mine operates intermittently but much of the time parts of the display drop out or jumble. It seems to be worse with high cabin temperatures but can play up any time.
EDIT: Just thought I'd bring up this old thread of mine as I've got my climate control apart on the table right now and would like to know if anyone has fixed one successfully before and if so what did they find.
https://www.sau.com.au/forums/topic/24948-r32-climate-control/
I had this problem. Some buttons didn't want to work either. Pulled it open and cleaned all the contacts and switches and stuff with contact cleaner and cotton buds. Worked perfectly for about 2 weeks then the buttons went abit intermittent but she works most of the time. Display works fine though
mine has a tendancy to not come on when i start the car, btu give it 30seconds and it will appear and all the buttons / display works perfectly after that. this only happens occasionally.
my theory is a loss of charge overnight and a bad solder joint rendering it incapable of getting enough current initially when i start.
i dunno...
  • 5 months later...
my screen used to garble and drop out on the odd occasion but i think the whole lot shorted out. i turned the ac off and while the screen turned off what actually happened was the fan set itself to demist and i could not stop it. the next day when i turned the car on it set itself to demist again. what the??? after a couple of days it seemed to fix itself. i drove to work with the ac on - no problem. i turned the ac off before turning off the car - no problem. when i got back in the car 6 hours later the whole cabin smelt like burnt plastic. ive since pulled the fuse for the ac and the smell is gone but ive had no ac for a few weeks now. ive had a brief look behind the ac unit and all the wiring looks fine - no melted insulation. will try pulling the control unit apart and see if theres any burns in there. if there is how much would i expect to pay for a replacement? apparently the r33 unit is the same as the r32 unit. if this is true i will buy a 33 unit as its newer.
yeah mine also is a little tendancy to occationaly work then not work, often with a quick tap on the screen it works again......very stange, thou must be a loose connection somewhere. I'm going to have to pull the unit out and check the soldering. Also whats the deal with the button on it which when pressed shows some sort of jap writting and degrees? is that outside air temp or wot?
Bit off topic sorry but alot of the funtions also didn't work when i bought the car on the climate control but they guy gave me a pile of parts which he thought were the stock amps or something, a bit off lookin around i realised that one was the computer at the back of the car which seemed to fix both the HICAS and the climate control when i plugged it in.
The little Japanese writing says ambient i think, but you should be getting the temp as well. Perhaps the sensor is not working? Dont ask me where it is though, i dont know.
MM2death said:
Yeah mine has a few funny things with it.  First, a couple buttons don't always work.  Secondly, the ambient temp button used to display the actual ambient temp when i got the car, but now all i get when i press it is some jap writing.......  Any ideas?
Scott
I pulled the control unit apart to look for anything a bit sus like dry solder joints or dirty contacts. 3 screws and the face unclips. 2 more screws and the front circuit board pulls off.
It is connected to the rear circuit board by a row of pins that push through a socket in the front board. This connection might be where some of the problems are.
I took out the 2 screws at the back and pulled out the back CB (tight). It looked like it had been resoldered before so I tidied it up and put the thing back together. I ran it for a few minutes and it performed like new so far. Fingers crossed.
Just pulled mine apart last night. everything looks fine so maybe mine is a prob with the wiring. will take it to an auto elec after ive payed rego. will let y'all know what the problem is so maybe can save the rest of you some money if you ever have the same prob. just hope it dont cost too much.
I think the AMB sensor is on the top of the dash, left hand side, very close to the window. Well its some sort of sensor
Ambient sensor is at the front of the car on the factory thermo fan.
As for not working.
Done a FMIC lately?, and removed it maybe.
i found some useful stuff on the climate control on this article, i think it was around page 30- 33 (diagnostic mode for the climate control, very interesting) would probally help alot of u guys find the problem with urs.
www.vspec.btinternet.co.uk/Links_files/Diagnostics.pdf
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
