hi guys, just had a few quick questions on an engine transplant. i have been forced into this and my r33 was written off, and me being no insured make's things difficult. The engine/gear box is all fine, so my plan is to drop it into a rolling shell and go from there.
1. Would it be worth doing an 180sx rb25 conversion? As I have all the hardware already and my uncle is a mechanic, best mate is an auto elec so it should be quite cheap. if i can find the shell
2. how much lighter is an r32 shell then a r33, would that be worth looking at??
3. how much should i be looking to pay, at the moment i don’t want to spend more then $2,500 on my shell. is that just to cheap??
4. where should i be looking for shell's, because i have only found 1 good one and its in cairns, im in Canberra so that kinda makes it hard :blush:. Other then that I haven’t found anything good
any other ideas you guys have would be great, as im not quiet sure what to do in this situation.
  • 1 month later...
^^ Thats not what he asked.
The RB25DET into a 180sx/Silvia is relatively easy. Just remember that the suspension wasn't set up to handle that kind of front end weight.
Here is a complete guide:
http://www.nissansilvia.com/forums/index.p...mp;hl=poor+mans
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
