I recently purchased a set of subframe bushes for my r32 gtr. I had pulled the subftrame out myself and took it pedders to fit the bushes. The problem is when i put the diff/subframe back in the car the swaybar was touching on the tailshaft. The new bushes dont sit flush with the subframe on the top but they do on the bottom. Is this normal? i cant remember what the old ones looked like. The new ones have about a 1.5cm extension on them like the diagram i drew. I'm a bit worried they sent me the wrong bushes.
https://www.sau.com.au/forums/topic/249532-subframe-bushes-r32-gtr/
You may have GTST bushes. I think they are the same apart from a raised section on the GTST ones, like you have. As far as I know the subframe is the same for GTST and GTR but the mounting points on the main chassis are what differs. Whiteline Plus do subframe bushes now, their tech department may be able to shed more light on it?
Thanks for the info i'll look into it asap and let you know what they say.
It sounds like you have the correct bushes, the GTR ones stick up about 2cm from the subframe. There is also a large washer that sits on top of the bush and spaces it down even further.
I'd have to have a closer look but the tailshaft should clear the sway bar by miles. Are both the tailshaft and sway bar bolted in fully? sway bar only fits one way so it can't be that?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
