Calm down,
Go down to marlows (super cheap auto) and buy a can of black touchup paint, also while you are there get some decent cut n polish.
mask up the area with masking tape, and spray very lightly over the mark (this is provided its not somewhere 100% obvious eg door, else it will make it look worse). Sometimes you are better off just dealing with the scratch.
if you really cannot do it yourself drop me a PM and ill have a look on the weekend.
https://www.sau.com.au/forums/topic/24957-touch-up/#findComment-530400
I agree with Dan, take it back to the panle shop you just got it done at. They more than likely just made a huge amount of money from your insurance company, they should be able to do a touch-up job for very cheap for you.
Why bother stuffing around doing it yourself, your car isn't a ferkin VB commodore!
https://www.sau.com.au/forums/topic/24957-touch-up/#findComment-530714
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
