hey guys,, i heard that changing your afm from the stock rb25det to the afm of the z32 may increase your horsepower, is that true? if any of you guys tried it i would love to hear the results cause i have one and would like to hear results b4 i install it also would they plug right in or would i have to re-wire the afm to fit into the rb's loom
https://www.sau.com.au/forums/topic/24958-z-32-afm/
point taken,, but tell me if i'm wrong, 1:- the field fuel controller reads the signals coming from the afm and then alters it a bit and sends it to the ecu so it ( the ecu) will adjust fuel accordingly,, on the controller i could have the car run rich or lean to my desire,, am i to assume the power fc does the same thing where the signal from the afm is concerned?
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-532443
It is a waste of time.
The Z32 is the same size as the AFM you already have, so it is not going to increase power. It will read higher airflows though.
Putting a 300Kmh speedometer in your car is not going to make your car go any faster.
Fitting a flowmeter that can read higher airspeeds through the same sized hole is not going to increase airflow.
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-534313
You have to find the power by other means, just changing the airflow meter and management to suit a different AFM is going to do nothing for you.
The only time fitting a Z32 is going to help is if your engine is already making more power, and the stock AFM has reached the maximum flow it can measure.
This will be when you are making about 220 rear wheel Kw or more. A Z32 will allow about 260 rear wheel Kw before you are in trouble again. A Q45 airflow meter is good up to about 300 rear wheel Kw.
Please try to understand the difference between making power, and the parts needed to support that power.
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-534879
  Quote
Originally posted by Warpspeed
...This will be when you are making about 220 rear wheel Kw or more. A Z32 will allow about 260 rear wheel Kw before you are in trouble again. A Q45 airflow meter is good up to about 300 rear wheel Kw....
i have a problem with this statement. im making about 190rwkw and im maxing my afm out - according to my powerfc.
is this a dodgy tune, or is that 220rwkw in victorian speak :)
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-535544
point taken again,, thanx,,warpspeed it seems as though you have some experience in this field, so maybe you can share some insight, i would like to know what sort of power i might acieve on my engine the mods that i am about to install 1- blitz dsbc 2 field fuel controller, 3 - 3" exhaust (already installed with no cat) cold air intake 4- bosch adjustable fuel pressure regulator. i know in stock form the rb25 is about 250hp,, how much should i expect with these mods, all the parts are here already and its waiting on me to install them, do you think i might reach the 300 mark anyone?
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-535575
geraldjohn, from what i read your "power mods" consist of
- boost controller
- fuel controller
- exhaust (no cat ... tisk tisk!!!)
- CAI
depends how much boost you want to run, but i think you'd be expecting about ~175rwkw at around 1bar.
im at 190rwkw with a light powerfc tune, and i havent touched fuel pump or injectors...this is stage 2 :) i have powerfc, super intake, front mount, exhaust and avcr @ 1bar boost - hiflow cat too.
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-535585
well, in NSW, Australia no catalytic convertor would constitute a fine of around $10,000.00AUD - if the EPA catches you.
its also highly toxic for the environment. so thank-you for contributing to worlds pollution problems and ensuring my grandchildren have a lovely environment to live in :)
https://www.sau.com.au/forums/topic/24958-z-32-afm/#findComment-535909
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
