Rb25det Engine , Gearbox, Clutch ,loom , Aftermarket Injectors
They have to machine the tunnel with the arp studs in because they change the clearance compared to the factory bolts
By Desean Strickland · Posted
Thanks for the response. I get why line boring the block could cause issues with a spline drive oil pump but I’m just using an extended flat drive collar, u reccon it could still cause issues? -
Apparently Mitsubishi are involved in this venture as well
By soviet_merlin · Posted
Ooo, quite aggressive! I hope there'll be a professional taking photos on the trackday that you can get. Should look great there!
