R34 GT-T at Tooronga Station, Malvern
To whichever lucky sod owns the Grey/Silver R34 ( complete with SAU stickers ) which parks at Tooronga Station, a word of warning:
I often see your car at the station in the arvos when I get off the train. Last night some dodgy character was scoping it out.
He looked in the windows and watched it from a distance so I watched him from a distance. He soon noticed me looking at him and he bailed.
I dunno if he planned to break in but I thought I'd mention it.
Cheers,
E
https://www.sau.com.au/forums/topic/24962-r34-gt-t-at-tooronga-station-malvern/
  • Replies 64
probably admiring
i do that sometimes
hang around a really nice car, look inside to see the guages and electronics and have a walk around the car, get a whole scope of the car
haha ill prolli get bashed one day doing this
Originally posted by INASNT
Hes playing with fire leaving it parked at a train station all day everyday!!
I gotta agree there mate. Its always parked in the same spot. Not in the Station carpark but outside it on the street. Very conspicuous. Well, I always notice it.
i remember reading once that a large % of car theft and breakins are from train stations... Bit silly to park any car there, never mind a nice 34
you're best off buying an unregistered crapper for $200 and driving to the station every day i think..
Originally posted by pushead
it will be hard to steal a car even if it is parked outside a train station in broad daylight. I dont know..
u recon?? after the morning rush at the train station, there is no 1 there very easy for a thief to steel a car in the middle of the day!
ahhhh...funny. It can take a thief less than a couple of minutes to disable even the fanciest alarm system. And how many people at a station really pay any attention to what is going on in the carpark?
you may as well just leave it parked at a shopping centre each day as well... with a big STEAL ME on the window..
but surely there wil be ppl walking around, cars zooming by.. ppl frm their houses looking out .
actually, i don't u'd need to, as another large % of cars stolen are stolen from shopping centres..
Anyway, my point is if you leave your skyline at a shopping centre for long periods of time or train station BAD BAD BAD BAD
Ok firstly, the 34 is never in the carpark, its always on the street outside the carpark. ( easy getaway )
Secondly, how many times have you heard an alarm go off and taken notice? Actually, how many times have you heard an alarm?
Most alarms go off and nobody ever flinches unless the alarm keeps them awake.
Guys, now i am worried.
I park in on the road rather than the in the station so cars coming pass can see it and anyone trying to break in.
I guess I will have to collect my car now and drive into work... damn petrol and parking costs.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
