Hey,
I have a RB25DET in my R32 GTS-T and its got a greddy copy plenum on it and it wont clear the clutch master, so i have put an r33 one in. Its brand new from nissan. I have bolted it to firewall and its connected the fork to the clutch pedal. I have filled it up with fluid and cracked the bleeder down the bottom and nothing came out, so i tried to take the bleeder right out and no good. So i cracked top bleeder and nothing... so i took the hydraulic hard hose off and still nothing, i looked inside it and nothing blocking it!!! So i put some vacuume line in and cracked top bleeder, and air is going from bottom through to bleeder... now im completely stumped as to why no fluid will go through the bottom hyd lines!!
any help is greatly appreciated! thanks
https://www.sau.com.au/forums/topic/249644-clutch-master-cylinder/
please.... any idea?
Had the same problem recently. Try this.
Adjust the piston travel to the master cylinder under the dash. If your issue is the same as mine the piston is too deep in the master cylinder and is blocking the bleed hole. Screw it so the piston goes back toward the drivers seat. Take it out a good distance at first and see if that cures your problem. Once you have fluid flowing you can bleed and readjust accordingly.
Hope it works for you. It did for me.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
