R35-gtr At The Strip - 10.55 With A 1.4x Sixty!
Every week these things just get faster and faster
104mph mid-track! can you believe that?
This is with relatively minor bolt-on mods
http://au.youtube.com/watch?v=xh-0EDLc7VI&...read.php?t=2759
I reckon we'll see 9's out of these before too long, insane!
but still lost the race...what was in the other lane?
me?
i think i may have a timeslip with the same time mph and 60 as that one
EDIT: ok watched the video...it wasn't me
Edited by DiRTgarage
^With launch control. All runs from here on out will be with lc. :laugh:
Yes, you read that right... 10.55. :irock:
Pulled the first GT-R sub 1.5 60ft too. 1.497 :OMG:
We were running the same setup as our previous 10.80 run; just playing with some boost control settings. Mostly offset changes; still running 17psi. Car was running 100OCT. Temperature was about 71. LC was used.
Big THANKS to Chuck_H as always for coming out (and shooting video) and to Eddie & Mike, my mechanics who have done such a great job with the car. We added a little bit of power to the car with some new stickers tonight. :rofl: Hard to see but the car is now sporting "Samurai Speed" on the doors. That's the new company I recently started (which Eddie and Mike are now a part of.)
Team Samurai Speed is making some great GT-R progress and we've got a lot other great stuff in the works. (This is only the beginning.)
AS ALWAYS... a HUGE THANKS to John Cobb for working so hard on tuning the GT-R's ECU and for creating a custom map for us.
Here's the slip...
Here's the video...
And, yes, that Grand National was fast. Chuck told me they announced that it was some sort of NHRA champion. Not bad that the GT-R hung within about a half second. :P I'm sure he wasn't expecting to have to reel me in at the finish.
10.55 @ 128.42 (Video Added) - NAGTROC - The Nissan GT-R Owners Club
Edited by Chuck_H
ok well it appears that same car has now broken it's transmission.
So this will be very interesting to see what has broken, and how they go about fixing it / making it stronger.
Yeah, 100+ launches with some serious mumbo. Great sacrifice for mankind.
http://www.nagtroc.org/forums/index.php?sh...=27307&st=0
Good to see how much of a beating it really took to bust the transmission. Finally a guy with a real story to tell and no BS.
Can't wait for the rebuild!
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
