ITEM : 18X9 & 18X11.5 DEEP dish chrome rims,
CONDITION : Great, couple little scrapes, tyres are about 60% tread.
EXTRA INFO : Made by SAWA design who make and design Rays rims, These have 14cm dish on rear , 7cm dish front. Offset is +6 rear +14 front ( freat to fill them guards ! ) Have also have the couple scrapes on the front face of the rims repaired :-)
PRICE : $2200 - ONO
PICS : YES BELOW
Edited by stylz7
https://www.sau.com.au/forums/topic/249656-18-deep-dished-rims/
Hey mate
Not sure if they will fit 32 GTR or not? I have seen 32 gtr's with wheels like mine with same offset but not sure if they were same width? i was allways told that with a GTR you should have same size rims front and rear but yeah?
Cheers
what car did you have these on? thinking about getting them for my r32gts-t with stock guards - will they fit or wil they stick out heaps? i'm assuming stick out, but by how much?
and are they heavy? two, three piece?
Hey mate
I had these on both my wide bodied 33 gtst and my wide bodied fc rx7, With out a wide body the rims stuck out about 4-5cm past the standard guards.
They are 2 peice rims and weigh about 8kg - 10kg or so each with the tyres
Cheers
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
