Wanting to lower my R34 a bit, something along the lines of the gaurds sitting just above the tyres, instead of about 1 1/2 inches above the tyres like it does now. I was looking at a set of king springs on ebay that are the "low" height ones, and just wondered if they would help to achieve what I'd like to get with my car... I'd like to see before and after pics of anyone that's done it with their R34 themselves.
I'm not even sure if my car has lowered springs because I've not really seen what one looks like with them. Coilovers are expensive and the struts in mine are fine, so I'd prefer to just get a set of lower, more rigid springs and a set of swaybars for it (I already have a front strut brace on it so I don't need that), so all I want to do with it now is lower it a bit.
This is what it looks like height wise, at the moment.
So is it on lowered springs?
https://www.sau.com.au/forums/topic/249657-r34-suspension-options/
I've got Tein Super Street Coilovers (Jap Spec, simply means springs rates are a little tougher then aussie version)
Got em from Slide Performance on the forums here very reasonably priced!
Heres a pic. Mine was lower but then made it higher to perform better on the track.
That's pretty much almost as high as mine man, I'd like mine to sit with a gap half that of yours between the arches and tyres, and get swaybars front and rear so it handles sweet...Apparently I can get Pedders sports riders for mine which are a lowered-spring shock, so they're made to take lowered springs.
In that case it looks like it might already be lowered?? Either that or when they made mine higher again its back to stock height... but still handles great. Also now mine gots front/rear sway bar heck of a difference so you are correct they'll make handling heaps better. Heres a updated pic from my iphone to see if car is actually different height now lol. Pic could of been deceiving.
A mate of mine has the pedders shocks not sure which ones in his 33 i assume sports riders and his car handles good.
BTW: are you rims 17's or 18's? my fronts are 17's and my rears are 18's.
You don't need to go coilovers if you just want the car lowered. You can just as easily, and cheaper too, get new shocks/springs that will give you the height you want and will likely provide a better ride. Plus they will be matched so wont kill the bump stops on the shocks and use up all the travel, like what will happen with lowered springs in standard shocks.
You can also get a set of plain old Bilstiens or something and have circlip grooves machined into them for SFA like I did, instant preset height adjustment of the spring base. Easy :(
Good luck mate.
I got 18s all round on my car Drew. They look sweet but having about 1 1/2 inch less gap alround between the wheels and arches will make it look so much sexier.
Back when I had my laser I didn't have a front sway bar at first, and on the mooloolaba exit heading north from kawana (the big round off ramp thing), my car would roll so badly in the front, and then once I got the sway bar for it there was about 70% less body roll, I couldn't believe it! So it makes heaps of difference.
Dan I really don't wanna have to go coilovers. Might have a look into them Bilstien shocks as they've got a pretty good rep.
Edited by tmg
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
