I expected some more gtrs anyways here are some shots from the day.
enjoy
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
The rest can be seen here:
http://www.flickr.com/photos/matthewmead/s...57611442618204/
and be ure to check out my website at
www.matthewmead.net
Specs on starlet please!
Should of come down for a looksee!!!!
Its running a Motec I know cause I was admiring the dash...Have a fetish for these things now LOL :P
Lofty: I seen you spinning the wheels after turn 1 was giggling..Whats the plan??? Better tyres and bigger wheels?
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
