Rb 25/30 Open To Offers...............................................
i have here for sale is my rb 25/30 setup
it comes complete with;
-rb30 bottom end
-rb25det head (recently serviced and machined with new welsh plugs) 5000ks old
-arp head bolts
-cometic head gasket
-extreme button clutch and chromeoly flywheel 5000ks old
-gates timing belt
the motor is overall in good condition bar a few little things;
-small oil leak in front cam seal
-head needs exhaust manifold studs re-tapped as i have stripped a few
-the rb30 bottom end is standard, it is NOT a built motor. still runs good
there are no manifolds or turbos sold with this setup as i have sold them already
$2000 ono
im open to offers and i am willing to seperate
rb25det head - $800 ono
rb30 block and gasket - $150 ono
arp head bolts - $100 ono
gates timing belt - $100 ono
extreme button clutch and flywheel - $850 ono
none off these parts are removed as yet so if you are interested please give me some time to dismantel
im located in windsor area
any questions call Alex on 0423 216 772
cheers
https://www.sau.com.au/forums/topic/249690-rb-2530-open-to-offers/
What RB30 block is it?
So it has the oil and water lines in the block?
Tensioner tapped into the block already?
Ill give you $80 for the block.
rb30 series 2 non turbo and yes it has all the water and oil lines in the block.
yes i have tapped in the tensioner as well
na mate i wont take $80 as yet as i have a few guys interested in the complete setup
send me a message in a couple of weeks and i will let you no how i go
cheers
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
