Strictly Performance Cruise [10th Jan]
GORINURTUNED
 Share
This is strictly performance car cruise abit of mix road for jap cars, if any of the commodores or fords coming to the cruise. Try to behave yourself at the meet points for those who are new in this scene and please follow the same old rules for those regular cruiser go on every weekends. This cruise is going to have 2 meet point for those who live northside and southside. Dont forget to put a full tank as well because is going to be a long night :laugh:. Bring a UHF if you plan to use it with your friends.
Northside Meet:~TBA
Time:~10:15pm~Depart 10:45pm
Southside Meet:~TBA
Edited by Hoshima
  • Replies 92
hey Stef...
does that mean that there are two cruises or we meeting up NOR and SOR and will meet somewhere central together?
i'll message you later man, i need new stickers because i'll need to replace my front windscreen now
cheers brother
hey Stef...
cheers brother
Yeah will meet up at the central Hoony :P
 Share
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
    • It could be. It might not be. It is impossible to know without context by asking the owner or the tuner on the day and knowing what they were doing/not doing/attempting to do. You said earlier this is hard to understand because to your mind, a turbo is at full speed when it hits its spike. This is not true. The turbos actual speed is defined by how much air is being forced through it via the exhaust, unless you control it. The spike you are seeing at ~whatever RPM it 'spools' at, is where boost control is starting. If there were no boost control the turbo absolutely would be spinning much faster at 7000rpm than 3000rpm, every single time, on every single engine. Boost control keeps the boost controlled within the limits you ideally want. If it were uncontrolled you would have two scenarios 1) You have a turbo that hits peak RPM and CFM (not boost) at the redline of the engine. This would work, but most people want more boost earlier. 2) You have a turbo that hits peak RPM well before the redline of the engine (say, 3500), and you explode the turbo by redlining the engine. (say, 7000rpm). If you don't want exploding things, or lag, you design a turbo system to come on when you want the boost to be useful, and then not overspin itself into oblivion by using some form of boost control, to control the boost pressure accordingly.
    • Yep. >10 posts required. Prank can relax that for individuals when required.
