Lastly don't forget that PS housings cost a few points of compressor adiabatic efficiency so they can be a slight step backwards if the thing is not surging , like most solutions they are a compromise with surge being the greater of the two evils .
very important point. no point getting a port shrouded/anti-surge cover just for the sound. they are only necessary on set-ups that suffer from surge. otherwise you are losing efficiency for nothing. well for the sake of a noise. it may sound cool, but not as cool your competitors only get to hear it as their car goes blowing past you... :P
  • Replies 47
The GT30R and GT35R use the same exhaust housing castings but machined to suit each turbine.
As Disco said. Anti surging the GT35R comp cover is probably going to cost you power.
I looked into this a while ago as I was interested to trial a 3076 in place of my 3582 but looking on the garrett site it didnt look possible. Not that the 3076 dwg is particularly clear.
http://www.turbobygarrett.com/turbobygarre...14568_1_2_3.jpg
http://www.turbobygarrett.com/turbobygarre...R_700382_12.jpg
Would of swapped right over but the comp covers are different.
Exhaust housings are same, same but machined to suit their different turbines.
We will often use a GT30R exhaust housing and machine it to suit a GT35R if there is no GT35R housing available as I’m sure most other turbo shops do as well.
Your calls I guess but I'm more interested in function and cost than advertising .
Really IMO PS housings turned up on HKS spec Garrett turbos because they knew people would run them with smallish A/R turbine housings and that they would surge with bigish trim compressor wheels .
If you go right through their range of petrol engine turbos you'll see that they also usually had a few optional compressor trims and that makes a difference too . Smaller (than the largest) wheel trim options is not such a bad thing response and thermal efficiency wise , with many wheel designs its often the middle trim size that the sweet spot and larger or smaller trims intended to bridge the gap with the existing and next larger or smaller diametre wheel families .
This is getting a bit off the track but I'd say the origins of these petrol BB GT (30/35 series) turbos came from HKS wanting Garrett to use their most modern wheels and putting them on a shorter smaller sized cartridge than they were designed for .
To make them "spool" early the housings also need to be small compared to diesel engine housings and this is why I reckon people have surge or creep problems .
If you use or recreate exactly a HKS model specific turbo you shouldn't get the problems because someones already sorted them out .
It's not the same deal with a Garrett generic turbo because they don't have the fixes in place , that's left to the user to sort .
Outa time , cheers A .
I opted for the PS because with it you eliminate the effects of surge.........I don't know if I had surge, but didn't really want the issue to start with. OK I may have sacrificed some power, but I could have also saved some grey hairs and $$$$ deducing that my problem was surge and then having to buy a PS comp cover as an extra. The downside, I could be loosing a bit of power for no good reason because I took the safe bet.
The PS comp cover also fits in with my future mod plans where I believe the chances of having surge will be greater.
PS Couldn't give a rats about the noise, not my thing really.
I dont think i sacrificed much power with the surge slots on my GT3076 .82
It made 293rwkw very easily on only 17psi (RB25DET) with a very basic tune.
Would have cracked 300rwkw with more tuning.
Dave,
Found this vid on youtube of an RB26 powered 300zx.
http://au.youtube.com/watch?v=gHToCueBeyo
It uses the BW S360, it sounds like it comes onto boost quicker than my GT3076 and makes 530rwhp!!!! Insane response and power!!!!
And the power band is huge!!!
A bit of a grey area but I think S200SX's and S300SX's are original BW turbos , mobs in the US alter them and hang slightly different names on them . Geoff Raicer (fullRace Geoff) is the one to ask about them .
A real GT3076R with a big A/R twin scroll turbine housing is supposed to top out at 570 Hp .
A .
570 at the motor, right?
The B-W's, from what I understand, run in generations kinda like the holsets (and Schweitzer for that matter). The non-extended tip ones are pretty much spot on with the holset HX series. The ones you are talking about being altered are still factory BW pieces, just the newer generation. BW and holset used to be real buddy buddy, but they split somewhat on the last generation of turbo's each produced. BW went in the direction of "extended tip technology" and holset went on to variably geometry exhaust housings in their HE series.
*Edit-BTW, that RB26'd 300zx is on NICO and I talk with him frequently on there. I think he went from a GT series to a BW looking for better response and found it IIRC.
Edited by Cjmartz2k
Hi all,
Im thinking of changing the front and cartridge of my turbo to a GT35R as the rear housing that i have is the same on both the GT3076 and GT35R? Correct?
Ive been looking for a Anti surge cover for it and the only ones i can find are the hole type like the T04Z and Turbonetics GTK turbos.
Is there a surge slot cover in .70 similar to the .60 on the GT3076?
Do they make this style of surge slot cover for the GT35Rpost-32255-1229854877.jpg
Contrary to suggestions that my new GCG highflow would be laggy on my RB25DET Stagea it actually boosted up really quickly low down producing surge. I have overcome it with my Jaycar IEBC which means that I can reduce boost at low injector cycles (engine load) to about 12psi and push it up again at high speeds (from about 3500 on) to 16psi. I am going to get an adjustable exhaust cam gear which should enable me to raise the boost lower down a bit without surging.
I think that the advantage of this over anti-surge slots is that the loss of boost induced by them would be felt further up the rev range (although it would probably be overcome at higher loads).
It sounds laggier than my GT3076R to me, and a GT3076R will make 530whp if it were tuned on a suitable motor with 85% ethanol blend - as well as spool a bit better.. Be very interesting to see a dyno plot of that car.
GT3076 make 530rwhp??
Thats over 370RWKW.
I will go go against the grain and say from what i have read on the internet, the bw
stuff seems to be laggier than the garret stuff, especially in 2J circles
cheers
darren
http://forums.evolutionm.net/service-parts...roll-gt35r.html
Seems not so in this case.
Also, I think the BW S360 is a way bigger turbo than a GT30r series turbo. It's a 69lb/min turbo so it should make close to 700hp at the motor. It's pretty much the same thing as my HX40 holset.
Here is a 300zx/FairladyZ running a BW360 in the states. Full weight (around 3600lb's) running mid 10's.
http://forums.nicoclub.com/zerothread/3814...-damned-time10s
    • Front wheeled vtec powered rb monster
    • Looking forward to the build thread!
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
