Correct :banana: Honda and EVO guys have been getting >500whp/low 10s out of them for years now.
I don't think any of the RB guys have been able to even come close to that number. I just spend 20 minutes going through the RB25 dyno thread and all the results I have seen so far for the GT3076 have been in the 240-290rwkw. The GT35r guys are putting down the kinds of numbers you are talking about though. I have also looked at several different sites and all the guys who are selling them advertise them as 500hp turbo's (not rwhp).
And about the 10's, super light weight honda's and not much heavier Evo's with AWD don't need much hp to run 10's.
  • Replies 47
Who on here has both maxed out a .82a/r REAL 56t GT30R (most of the ones in the dyno results thread aren't or are only on 1-1.3bar) or even better, on race gas? I said that number in reference to guys maxing the turbo out on C16.
In this list you can see a few cars running FP 3052 (basically a GT3076R from Forced Performance) doing around the 10s at >130mph in Eclipses which weigh >1300kg, or basically R33 GTS25t weight but with 4WD transmission loss. You'd need a few hps to do that in a street car of that weight....
http://dsmtimes.org/times.php?Page=1
Noone on here has really pushed a real GT3076 to the limit so i guess we wont know until someone does.
Hopefully me, when i get my car back together and tuned on E85 :banana:
Nice, I really look forward to seeing how that goes - it may well surprise a few people. Is that something that might be happening soonish?
This puts into perspective how useable and potent a GT30R can be, running 470whp (350wkw) on pump gas in a FWD Honda in the US - remember this is a MPH speed, these little bursts of acceleration would have to be in 4th and 5th gear.... so light car or not thing engine is really making some power and torque:
Edited by Lithium
While this may be the case, I still can't see a GT30 anything making 570rwhp. TheMafia on here is running one with water/meth injection and is around 400rwhp. Maybe he can get more out of it, but 170hp more?
Also, no matter what a GT30r can make, the BW S360 is a MUCH bigger turbo with MUCH higher hp capabilities. It's bigger than a GT35r.
I'm not trying to say the GT3076 isn't a fantastic turbo, it just shouldn't be compared to a GT3076.
No and you won't run a GT3076R to its gas flow limits with a 0.82 A/R turbine housing .
You need to go back to the turbine flow map of the GT3076R (700382-12) and see the difference between the 0.82 and 1.06 A/R turbine housings .
I really can't understand why people make the jump from GT3076R's to GT3582R's without having tried the 1.06 housing first . Blind Freddy can see from the maps that most are running out of exhaust flow not compressor pumping capacity .
There is no guarantee that a GT3076R with with a 1.06 turbine housing will have a higher boost threshold than a GT3582R with an 0.82 hot side , what you can see is that the petrol GT30 turbine map looks a lot better than the petrol GT35 one .
I've had suspicions for a long time that Garrett jerked everyone off with the turbine housings on 3582R's , I suspected that they were machined out GT30 castings and someone here recently confirmed that they "make" GT35 housings out of GT30 ones if they can't easily buy them .
The upshot is that you get a higher expansion ratio in larger A/R turbine housings and if the turbo is sized properly you often don't get the turbine lag that people quiver over .
If you want to look at diesel engine turbos there are only a few with the 76.2mm GT37 compressor - GT3576 and GT3776 . Both use GT40 compressor housings and compared to petrol GT3076Rs huge hot sides .
To have any hope of getting all 43 beans out of a GT3076R you have to use the 1.06 turbine housing .
A .
  • 7 months later...
Dredging up an old thread but has relevance ATM .
Just wanted to mention that for people wanting to extend the capabilities of their GT3076R's have a think for a sec about the respective GT30 and GT35 exhaust housing castings probably being the same .
Same flange size and in theory same A/R housing but with a bit more of the guts profile machined out if its intended for the larger 68mm turbine wheel .
I'll try and get the links for the turbine maps of the GT3076R and GT3582R turbo from turbobygarrett . If you look at the GT35 one the lines do a gentle curving climb where the 30Rs ones rise to a point and flat line or plateau if you like .
Out of time more tonight , A .
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
