ok guys, another 32 with fluctuating oil pressure readings from the guage.
Been doing some reading and searching on here, and the majority feel is the bloody pressure sender, and seems to be a VERY common fault.
Anyway, here is my plite.
Have my lovely R32 GTR, did an oil change, and a few days later, I have noticed that sometimes (not all the time) the oil pressure gauge seems to show the pressure as being close to (but not quite) zero.
The oil used in the change was Mobil 1 SuperSyn (not sure of the weights, but will check), not sure if it might be too thin for the engine, causing it to have slightly lower pressure to normal.
I also suspect the oil pressure sender, as it's probably the stock original unit, does the R31 RB30E unit fit as a direct replacement, because I have a new sender on my RB30 which is sitting gathering dust unregistered, and I can rake parts from that if needed.
I also know the Oil pump was replaced about 10,000kms ago in this car for a new unit with sleeve, so I am shy-ing away from the oil pump being a problem at this stage.
Car is getting a mechanical oil pressure gauge to confirm the pressures today, but it still chill's me to see oil pressure drop low on such a motor.
Anyway, main question is will the RB30E oil pressure sender fit as a replacement to the R32 RB26DETT unit, or should I scrap the stock and shove an aftermarket unit in instead?
Thanks in advance and Merry xmas all.
B.
https://www.sau.com.au/forums/topic/249794-r32-gtr-fluctuating-oil-pressure/
its the sender mate, mine was exactly the same. i did the mechanical test and all is fine, i put an after market (autogauge) pressure unit in the stock location and it reads perfect.
good luck
The weight of the oil affects the pressure reading. The quality of the oil also affects the reading slightly.
I have the same car (unopened engine with 80k on the clock) and I was using Castrol Edge 5w30 for about 3000k, and noticed the oil pressure is quiet low (sits on 1 sometimes) and increased to 3 when I drive it a bit hard and on highway, but it would fall lowish to ~1 after that.
I then switched to the same oil but 10w60 and saw the pressure stays mostly just very slightly above 2, and would climb to just under 4 when driven hard, but it would sometimes, very rarely falls to ~1 after that. Car also feels laggy as well, so I think its not the right weight of oil, even though on the castrol website, it recommended it.
So the last oil change, I switched over to Motul 300v 10w40 and found that the oil pressure is a lot stable. On idle and normal driving, it would sit on or just under 2, and climbs just a little bit over 2. When driven hard, it would climb to 3 at the maximum and falls back down to the 2 after that, so the pressure is a lot stable. Car also feels more responsive then when I was on 10w60. After reading all the article on oil base stock and actually seeing the difference myself, I will only ever use 300v in my car now. :-)
Btw, I think its better to get a good quality electric oil pressure gauge instead of the mechanical gauge, since I don't particularly like the idea of running hot oil straight into the cabin.
Defiantely sound advise, it's also defectable to route engine bay fluids into the cabin, let alone the potential for failure.
I will be investing in an electronic oil pressure gauge shortly, will be using the mechanical gauge ONLY to confirm the current situation, to make sure my engine is not going to let go at some stage.
B.
its a GTR the engine is destined to let go at some point.
Oil weights play a major role in hot pressures. I use nothing but the edge 10W60 in the RB as I have had oil test samples done from several oil brands and its results were the best for my application.
It does sound like you have a sender issue and No the RB30 sender doesnt work. Its just a simple idiot light switch and cant opperate the guage in the GTR.
Did you ever check the pressure with a proper guage??
Got the pressure checked with a mechanical guage, have the figures at home, pretty decent pressure actually, but while the car's pressure switch was out, we flooded it with WD40/RP7/CRC lube spray, and it was caked with crap and rubbish.
Gave the mongrel a good clean, and after re-fitting it, the pressures have returned to 'normal' on the guage.
Oil currently in it is 10w-50 Mobil 1, and she drove up to and back from Brisbane without missing a beat. Also drove around in Stop/start traffic on NYE in the 39 degree temps (didn't like it, but survived).
Still keep a close eye on the guages, but hopefully all good now.
Being a GTR, I know one day the engine will let go, but the previous owner spend a good $12k on the engine prior to me getting my hands on it, so I am hoping it will last a little longer than a few months.
B.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
