  • Replies 85
edit---TODAY--i was down at welshpool (getting my licence re-newed, no yellow sticker) there was stuff all cars there, a disgusting red celica with huge chromies, and a pig s13.
THOUGH i went in n came out in 30mins and the line hadnt moved at all. that was around, 2pm
Edited by Char
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4333523
how did you go ricca, no luck for me. got to see if my brides are adr approved, my park light reflector has to be secured, high level stop light, need tyre plark. car re weight. need to have proof that the car doesnt come with a air bag. high beams. (they worked before i left to go) got to fill out this mod form and send it through and prob have to get a engineer to look at it.
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4334598
sorry if i am jacking this thread, but how am i meant to prove that my car doesnt come with air bags
the easiest way to prove you dont have airbags is to look at your dash lights. If you have an airbag, upon igntion of the car, the airbag light will come on for a brief few seconds as a self check. If there is no airbag light at all on the dash...the car never came with it.
Edited by ZXY
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4335789
mmm when i got a yellow and went to the pits i went to the gosnells one *i had a yelloow for a T wing* i got this guy with like skin disorder and he raped me :? saying my suspension is wayyy too hard and couple of other stpuid stuff so i got my mom to take my car over at welshpool and it was done in less then 10 secs :) so yeah if i was to get a yellow again ill get my parents to take car over LOL
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4336067
Well thought i give an update.
I have since my last Check installed a new
Immboiser!!
inner toe arm
fixed the Suspension
and made a bracket for the Zaust
Heading over the pits on Monday not sure where yet i have got a friend which is a Engineer and getting his Cert to Clear his own cars
he would be taking it down so he can talk the talk!!
So hope all goes well!
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4352960
where would the engine number be on the 26, the inspector couldnt find it cause he said the turbos are in the way
Exactly where he's looking. There's a little bit of the block that sticks out, on the passenger side, up against where the gearbox bellhousing bolts onto the block.
He might need to use his little bendy mirror and get at it from the underside..
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4354713
actually found the engine number, i guess on a 26 its different, its directly under the top radiator hose on the block
lol fair enough, they probably moved it after they realised they'd put a bunch of turbos and stuff in the way :)
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4355601
Guest
