Im starting to collect parts now for my goal of ~320AWKW.
My R34 GTR was stock when I bought it, I have installed the following:
* Exhaust: HKS Front pipe and Cat Back with Hi Power Muffler.
* Fuel: Nismo Fuel Pump and Fuel Pressure Regulator.
* Control: HKS EVC 6 Boost Controller
* Intake: HKS SPL Piping Kit with Super Flow Pod Filters.
Current Power: 240AWKW at 1.2 Bar
What Ive decided Im going to get:
* Garrett 2860R-5 (GT2560R) turbos. Im hoping to make 320AWKW at same boost Im running now. Is this possible??
* Tomei Cam Gears.
* Power FC
What Else Do I need?
* Do I need a new clutch for 320AWKW? Single or twin plate? I know zero about clutches.
* Do I need to buy injectors? 700cc? Or can stockies handle 320AWKW?
* Do I need new Air Flow Meters?
* Do I need new gaskets for the -5 turbos? Anything else?
* Do I need Oil Catch can?
* Stock R34 GTR FMIC should be OK for this power, correct?
* Anything else?
Note: Engine is internally stock which is why my goal is 320AWKW on a safe tune which the RB26Dett should handle, and not a massive figure. Will get it tuned for response and torque.
What would 320AWKW be at the fly wheel?
Cheers
https://www.sau.com.au/forums/topic/249812-goal-320awkw-r34gtr/
  • Replies 73
Wow your going all out now mate!!
Probably would want the injectors and perhaps a power fc djetro cos the AFM's would be maxing; my injectors reach 80% now on full load @ 255awkw
The clutch....well i have a nismo twin plate, the coppermix one and its great! not too grabby but strong enough to cope with high power. May be a bit expensive now with the yen the way it is.
Dont want D Jetro as It will make the Pods sit even closer to the motor with My SPL pipe kit cause piping will be shorter with no AFM's
Wont be installing new parts soon, more like in 9 months time. Just starting to collect parts slowly.
forget the afm's bakes and put a Vi-PEC plug-in ecu in it. Keep the stock afm's in place just unplug them. You could even have dual maps...one for afm mapping on lower boost and one for higher boost to read the map sensor.
was asking around at Autosalon for you but you were unavailable...sweet car mate
Edited by DiRTgarage
is your bottom end factory? then again if u have an r34 1 would assume this would be stronger than my previous 2 r32 gtr's...my 1st gtr had 365awkw & bottom end let go...my 2nd gtr has 325awkw & this also dropped compression (ring land apparently)
Wrong turbos.
GT-SS/-7/-9
The -5's are too big for 320
This has been covered i dunno how many times... All those questions have been answered in about 2-3 big threads :P
-5 are perfect for 320 and much more if needed. Ive done the turbo research on this forum and on GTR UK. So many people are running -5 and are more than happy with them. If tuned properly response can be close to stock turbo response and they will do it at less boost than GTSS eqivalents
yeah bottom end is stock on mine. Plenty on GTR UK forum have said this power level should be OK on R34 GTR
No they are not perfect for 320, sorry but that's wrong
There is so much info on this forum to back this up now that if you wanna believe something different then go for it, although I'm not sure where you'd find -5's are the best turbo for 320 on this forum i don't think I've seen any thread saying that.
-5's have made over 400kw @ the treads, and consistently mash out 380 on many many cars... so there is no way they are suited for 80-100kw (over 200hp @ the motor) less.
If all you're aim is set at 320awkw, then what do you need turbos that are capable of a LOT more for exactly?
GT-SS/R34N1 and the usual suspects (-9/-7) are the turbos for 320awkw.
Dyno sheets showing 'response' mean nothing on the street where in between gears, transient response and everything else is king. You cannot measure that on a dyno with a car loaded up showing near similar response when infact its simply not.
As for people being happy with them... they don't know any different :P
Get in a car with appropriate turbos for 320, and then get in a car with -5's
Be the judge that way.
Mate I asked all of these questions almost identically actually.
Check my thread, it covers what you're asking.
http://www.skylinesaustralia.com/forums/De...in-t236467.html
Cheers and good luck. Chuck up a sheet when you get it done and enjoy!
i think you may be confusing -5's with -7's
DiRT: He can't be if he's pointing out they are better than -7's/GT-SS's at the end of his post - He just genuinely thinks they're better options.
Bakes: Dyno results seem to show -7's will be more responsive than -5's at this power level. Cams and gears can be used to help the -5's but the rule of thumb appears to be they're a touch too big for 300-330kws.
Edited by ActionDan
i think if its a daily driver, then -7's would be the best choice, however if more like a weekend car, -5's... purely because every time that i want to jump into it, i feel that its going to be much quicker when boost comes on and you would enjoy that rush more so! thats why i bought the -5's over the -7's! and yes, i am very happy with them! i have been in an identical gtr to mine but with -7's and can say i do not regret what i did... also, it comes down to if you have future plans for the motor, these turbos would be a great investment should you have to rebuild your current rb26 and not having to worry about spending another 2k + on turbos at that time.
http://www.gtr.co.uk/forum/96210-5s-7s.html
Ive already ordered the -5's. (2560R)
If I blow the stock engine I will already have the turbos to then go for 400kw.
Have spoken to people who get 1 bar at 3500rpm and 1.2 bar at 4000Rpm so response in between gears will be sweet.
If you factored into your plan blowing up your motor so you need to build a 380 ~ 400kw stong bottom end ... then sure, -5's may be your thing.
But if you want response and driveability, -7's or GT-SS's are leaps and bounds more suitable for a 320kw motor.
Edited by Antimatter
lol, I didnt factor in blowing up the motor. Its just that I can get the power the GTSS make with -5 with less boost. So GTSS are not leaps and bounds ahead, maybe 500RPM on response.
Clearly you didnt read through the thread I linked. Plenty are saying there is little difference in response.
Each to their own, for each person saying to get GTSS or equiv there will be another (or more if you look at the linked thread) to say to get -5s.
Anyway, my thread was not in regards to what turbos I should buy. I have decided that. I made the thread to ask about other items I may need as per my original post. Not really interested in the GTSS vs -5 turbo war.
So far Johnny has helped by suggesting a Nismo clutch.
That GTR UK thread didn't really have much and i read it end to end.
Not a lot of back to back testing, track testing etc. Just some saying they had this, it was good.
Exactly what i said above about people not being in other setups and so on.
All which has been done here in Melb to a very large degree. Many of my mates have GT-SS, -5s/-7s and other varying configs including myself.
Like you said, if you blow the stock motor (which, lets face it is going to happen eventually), you can make 400rwkw
Good luck with it.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
