when driving hard and about to go for it, your always going to be right at the start of boost so why not benefit from which give you more power all the way through the high revs, the -7's will run out up high wher the -5's will keep going consistently.
Bakes... you wont regret.. trust me! i was in the same boat and was glad i didnt go for the -7's. Its also an investment for future plans.... perhaps! :P
  • Replies 73
im running GTSS turbo's - making 325awkw @ 21psi (apparently -7 equivalent)
previously i had a GTRS setup & made 362awkw @ 21psi (apparently -5 equivalent)
both were done by the same tuner - & yes the GTRS came on boost later than the GTSS which was a difference of approx. 2000rpm (& if felt like a lifetime for full boost on the GTRS) BUT the top end rush of the GTRS is awesome, so both turbo's have their pro's & con's!
IMO - if u wanted a circuit or street car i'd go with the GTSS equivalent, if u wanted 1/4 mile or top end rush u'd go with the GTRS!
either way, -5 or -7 u will be wrapped :P as anything over 300awkw is SHWEET!
Poor bloke just wanted the supporting mods..
As others have contributed. 700cc injectors , 044 fuel pump or drop in jap, ecu upgrade , clutch , requisite exhaust from turbo back (dumps / front pipe), 1 bar adjustable actuators. Some adjustable cam gears at the very least , my prefference is for cams but, being able to tune them well costs and not alot of tuners seem to know their way around with them.
On the turbo side here is some GTR data taking from the forum GTR owners, of which there are now a number running different turbos.
the GT-SS (-9's) are unbeatable under 350rwkw & 2530's / -5's over.
The data taken from the RB26 dyno results sticky for various turbos.
Peak power:
The average for the 2530's is; 388rwkw
The average for the GT-SS is; 335.4 rwkw
The average power made by the -5's is; 313rwkw
Of the same data the best power of the -5's was 388rwkw
Best of the 2530's was ; 451rwkw.
Best of the GT-SS was 364rwkw
Now if we are going purely of budget un-opened/ non-built motors maybe with just some drop in cams it looks like this;
-5's average ; 298rwkw
2530's average ; 358rwkw
GT-SS average ; 332rwkw
Taking cars that make more than 400rwhp, std stroke, bp98.
average power over;
110kmh
130kmh
150kmh
180kmh
GT-SS = 265rwkw
2530s = 284rwkw
-5's = 242rwkw
taking just 110kmh & 130kmh to indicate the 'reponse' and mid range
GT-SS = 218rwkw
2530s = 196rwkw
-5's = 174rwkw
Great Thread!.....ive been down this path, so here's what ive done to get similar power (im running 317awkw)..
r33rb26dett (unopened bottom end)
R34 N1's (-7's equilavent?)...no choice here as it came with my 2nd motor)
bosch 044 fuel pump (internal mount)
nismo 555cc injectors (running at 90% duty)
arc intake and cold air box
3" exhaust with aftermarket dump pipes
power fc Tune + boost tap
This is an extremely nice car to drive daily, and the response is awesome for the street!....im really happy with the tune..i need an EBC as boost dips off with my tap...
If i had a choice now though, i think i would go for -5's, as id like the bigger hit when it comes on boost as right now its extremely progressive...i dont mind the lag, and generally lag is 1st gear....
Your choice...either way 300+ is going to be fun to drive for you
good luck
Peak power:
average power over;
110kmh
130kmh
150kmh
180kmh
GT-SS = 265rwkw
2530s = 284rwkw
-5's = 242rwkw
GT-SS = 218rwkw
2530s = 196rwkw
-5's = 174rwkw
great post!
Huge lol at how this thread became a turbo war.
People are happy with their -7s, people are happy with their -5s, people who have gone from having -7 to -5 are also more than happy.
Thanks to the people who have actually helped me out with answers related to the actual reason why the thread was started.
:P
yeah confirmed that, -5's are not the GTRS's..... The equiv is between -10's and GTRS's which is a much larger turbo and should only be used on a built rb26 + !!
i stand corrected - yes it was the -10's that were the badest!
The data rev210 has put in is good but there is not enough, especially if the average for the -5 is only 313rwkw, misleading and conflicting to others opiniions, I thought they were only good for 380-400Kw, lol.
Averages are only as good as the data input into them.
My rb26 has -5 turbos but I choose to run it a 430rwhp. They are by no means maxed out.
Best thing to do is look at the turbo compressor maps & info available on the Garrett website.
http://www.turbobygarrett.com/turbobygarre...ech_center.html
It will make more sense thatn endless opinions about who likes which turbo best.
You may find the 707160-9 is very nicely matched to your application.......
Edited by djr81
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
