when driving hard and about to go for it, your always going to be right at the start of boost so why not benefit from which give you more power all the way through the high revs, the -7's will run out up high wher the -5's will keep going consistently.
Bakes... you wont regret.. trust me! i was in the same boat and was glad i didnt go for the -7's. Its also an investment for future plans.... perhaps! :P
  • Replies 73
im running GTSS turbo's - making 325awkw @ 21psi (apparently -7 equivalent)
previously i had a GTRS setup & made 362awkw @ 21psi (apparently -5 equivalent)
both were done by the same tuner - & yes the GTRS came on boost later than the GTSS which was a difference of approx. 2000rpm (& if felt like a lifetime for full boost on the GTRS) BUT the top end rush of the GTRS is awesome, so both turbo's have their pro's & con's!
IMO - if u wanted a circuit or street car i'd go with the GTSS equivalent, if u wanted 1/4 mile or top end rush u'd go with the GTRS!
either way, -5 or -7 u will be wrapped :P as anything over 300awkw is SHWEET!
Poor bloke just wanted the supporting mods..
As others have contributed. 700cc injectors , 044 fuel pump or drop in jap, ecu upgrade , clutch , requisite exhaust from turbo back (dumps / front pipe), 1 bar adjustable actuators. Some adjustable cam gears at the very least , my prefference is for cams but, being able to tune them well costs and not alot of tuners seem to know their way around with them.
On the turbo side here is some GTR data taking from the forum GTR owners, of which there are now a number running different turbos.
the GT-SS (-9's) are unbeatable under 350rwkw & 2530's / -5's over.
The data taken from the RB26 dyno results sticky for various turbos.
Peak power:
The average for the 2530's is; 388rwkw
The average for the GT-SS is; 335.4 rwkw
The average power made by the -5's is; 313rwkw
Of the same data the best power of the -5's was 388rwkw
Best of the 2530's was ; 451rwkw.
Best of the GT-SS was 364rwkw
Now if we are going purely of budget un-opened/ non-built motors maybe with just some drop in cams it looks like this;
-5's average ; 298rwkw
2530's average ; 358rwkw
GT-SS average ; 332rwkw
Taking cars that make more than 400rwhp, std stroke, bp98.
average power over;
110kmh
130kmh
150kmh
180kmh
GT-SS = 265rwkw
2530s = 284rwkw
-5's = 242rwkw
taking just 110kmh & 130kmh to indicate the 'reponse' and mid range
GT-SS = 218rwkw
2530s = 196rwkw
-5's = 174rwkw
Great Thread!.....ive been down this path, so here's what ive done to get similar power (im running 317awkw)..
r33rb26dett (unopened bottom end)
R34 N1's (-7's equilavent?)...no choice here as it came with my 2nd motor)
bosch 044 fuel pump (internal mount)
nismo 555cc injectors (running at 90% duty)
arc intake and cold air box
3" exhaust with aftermarket dump pipes
power fc Tune + boost tap
This is an extremely nice car to drive daily, and the response is awesome for the street!....im really happy with the tune..i need an EBC as boost dips off with my tap...
If i had a choice now though, i think i would go for -5's, as id like the bigger hit when it comes on boost as right now its extremely progressive...i dont mind the lag, and generally lag is 1st gear....
Your choice...either way 300+ is going to be fun to drive for you
good luck
Peak power:
average power over;
110kmh
130kmh
150kmh
180kmh
GT-SS = 265rwkw
2530s = 284rwkw
-5's = 242rwkw
GT-SS = 218rwkw
2530s = 196rwkw
-5's = 174rwkw
great post!
Huge lol at how this thread became a turbo war.
People are happy with their -7s, people are happy with their -5s, people who have gone from having -7 to -5 are also more than happy.
Thanks to the people who have actually helped me out with answers related to the actual reason why the thread was started.
:P
yeah confirmed that, -5's are not the GTRS's..... The equiv is between -10's and GTRS's which is a much larger turbo and should only be used on a built rb26 + !!
i stand corrected - yes it was the -10's that were the badest!
The data rev210 has put in is good but there is not enough, especially if the average for the -5 is only 313rwkw, misleading and conflicting to others opiniions, I thought they were only good for 380-400Kw, lol.
Averages are only as good as the data input into them.
My rb26 has -5 turbos but I choose to run it a 430rwhp. They are by no means maxed out.
Best thing to do is look at the turbo compressor maps & info available on the Garrett website.
http://www.turbobygarrett.com/turbobygarre...ech_center.html
It will make more sense thatn endless opinions about who likes which turbo best.
You may find the 707160-9 is very nicely matched to your application.......
Edited by djr81
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
