The data rev210 has put in is good but there is not enough, especially if the average for the -5 is only 313rwkw, misleading and conflicting to others opiniions, I thought they were only good for 380-400Kw, lol.
Bakes...if you want real expert advice on low mount turbo's i know someone who has done back to back testing on 8 different low mount turbocharger applications using the same test mule and the same dyno with almost identical atmospheric conditions. Comparing different results from different cars, different dyno's and even different countries is going to give lots of conflicting info.
PM me if you want to find out more.
  • Replies 73
Cheers Paul, as you say there will be conflictions everywhere. My brothers picking up the -5's for me today, Ive made my decision.
Here is a link for those interested on GTSS vs -5 done on the same car on the same dyno. If you look at the first graph the -5 were 500 rpm behind the GTSS up until ~4600rpm where they draw level but at 5500rpm the -5 pull ahead of the GTSS.
http://sthitec.blogspot.com/2008/05/gt-ss-...or-2560r-5.html
Again, there will be other evidence to say the opposite on other cars probably but Im just continuing the way the thread has gone, lol. Keep the war going :P
Im sure I will end up at the power level shown in the graph one day anyway.
The potential of the turbo's themselves isn't what I was alluding to.
These are only the cumulative results people have independent of location and tuner as averages.
Just as an observation it appears universally easier to extract good power from the GT-SS in the sub 350rwkw range.
This is easily predicted by the compressor map as another person noted. They have the best of the -7 and -5's rolled into one.
From the compressor map they will spool as quick as a -7 but, require as low pressure to flow 30 as the -5's meaning less generated heat for power 250rwkw or more.
There is absolutely nothing wrong with the -5's they are fantastic turbos and those tuners who have thier heads around them can get as much power and response as one could every want on a road car. Sure the -9's/ GT-SS are something special but, they don't have the legs of the -5's.
All you have to do is make sure you start building a spare motor and buy a spare gearbox if you decide to wring the max out of the -5's :P
im doing the same as you mate using the 5s
using the stock cooler see how it goes....
power fc
sard 720cc inj
sard fuel pump few little mods needed to fit in....
twin plate clutch os lightened fly wheel...
im going to use nismo afm bolt straight in....
hopeing to run 20psi and see how the stock cooler goes.... hopefully make around 350rwkw
also i have been told to just use the stock cams and use cam gears to get the best responce!
mine is a r32 tho....
so yes inj you will need!
i would go with the 720s head room for more! why go 550 if you need to go bigger later on?
my 440 stockers were 95% maxed out at 262rwkw
clutch i would say so.....
my os was not cheap! but its a strong clutch and with the lightened fly wheel the top end pull from 5500 up is much faster!!!!!
afm yes either z32s or nismos i would go... nismo just bolt in no cutting wires changing plugs ect...
gaskits yes i have been told some one sells them as a kit for about 250
oil return bolts you have to drill out so i have been told also nothing to hard.....
Cam gears are a good idea.
If your tuner reccomends stock cams then stick to those. I'm not of that school but, I'm also not your tuner :O
You will have a weapon with this setup like the bloke who started this thread. -5's are a top turbo for ultimate street power :P
  • 2 months later...
  • 10 months later...
Bit of a thread revival by the arabian drifter but its actually timely:
Turbos, injectors, ECU, cam gears and a few other goodies should be getting installed and tuned in the next 2 weeks or so.
Stay tuned (pardon the pun)
who are those hotties in your avatar??? OMG...fark me
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
