OK.
I'm having a conundrum. I recently put on a Carbon Z-Tune bonnet and whilst it looks f*cking awesome is it really helping me. Yes it lowers my engine temp by up to 11deg and I loose like 10kg of weight but since iv'e put it on I think the rain has messed with my coilpacks. My car idles and drives A OK but under full bost now it starts to flutter and I lose all boost. If I let it get up to boost slowly she'll go but if I stomp it I get nothing as soon as boost comes on. I have the coil pack cover off with Splitfires. A mate said it shouldn't matter but it has to be the issue.
Anyone got any ideas on this one?????
https://www.sau.com.au/forums/topic/249828-vented-bonnets-and-rain/
I'm hoping the hot weather will do this for me!!!! It was pretty damn hot yesterday and it was in the sun all day. Went for a drive last night and the same thing happened again. I'm thinking I may have to take them off and give them a clean.
get the water out, then put your cover back on. there is no need to run without it. look at most serious circuit cars. they run WITH the cover. there is no need to take it off.
I had similar issues, but the car was not barking down like yours. it just made a mess around and under the coil packs.
i just run it with the cover on and not worry about it anymore. i do however keep a car cover over my car when not driving it.
Best remove and clean the boots with silcone spray and a light smear of silicone grease. The gasket around the cover goes hard with time, but can be replaced with o-ring cord available at places like CBC.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
