Any front end will go on, but it most definitely won't be a straight swap. That is only possible on S13 silvia/180sx because they have the same chassis and doors.
You will need conversion guards, but I doubt anyone makes them, so you'll need to cut up both pairs of guards and join the S15 guards to the cefiro guards. You'll need custom headlight mounting brackets. Don't know if the S15 front bumper reo fits on the cef or not, might need to cut and weld the S15 reo to the cefiro one to fit it. Bonnet, if you are lucky it will fit, otherwise you might need to do something there (like get a fibreglass one and make it longer?)
It's not like this kind of thing hasn't been done before, (think sky-firo, 180-line, s15-80, cef-line), but is going to depend alot on your patience and wallet
BAHAHAHAH sorry, but yeah not even a chance.
The parts that they share with silvias (S13) refers to things like,
front end: shocks, hubs, uprights (hub carrier), brakes, strut brace, control arms, castor arms
rear end: diff, driveshafts, suspension, hubs, uprights, camber/toe/traction arms.
Parts that are shared with skyline, engine and gearbox (slight differences), rear brakes and handbrake, seats.
When it comes to body panels, only thing that comes close to fitting is the laurel, (think laurfiro). Essentially the laurel is the same as a cefiro, except they have a different body shell. But unlike the s13 silvia/180sx, the doors are not the same so you have problems getting the laurel guards to line up with the cefiro doors (they rub and the body lines don't match).
R32 front end?
Dont the ceffie and 32 share the same chassis
Cef's don't have the same chassis as anything except for laurels. There are similarities in certain parts, but like I said before you'll need conversion guards, custom head light mounts among other things.
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
