Any front end will go on, but it most definitely won't be a straight swap. That is only possible on S13 silvia/180sx because they have the same chassis and doors.
You will need conversion guards, but I doubt anyone makes them, so you'll need to cut up both pairs of guards and join the S15 guards to the cefiro guards. You'll need custom headlight mounting brackets. Don't know if the S15 front bumper reo fits on the cef or not, might need to cut and weld the S15 reo to the cefiro one to fit it. Bonnet, if you are lucky it will fit, otherwise you might need to do something there (like get a fibreglass one and make it longer?)
It's not like this kind of thing hasn't been done before, (think sky-firo, 180-line, s15-80, cef-line), but is going to depend alot on your patience and wallet
BAHAHAHAH sorry, but yeah not even a chance.
The parts that they share with silvias (S13) refers to things like,
front end: shocks, hubs, uprights (hub carrier), brakes, strut brace, control arms, castor arms
rear end: diff, driveshafts, suspension, hubs, uprights, camber/toe/traction arms.
Parts that are shared with skyline, engine and gearbox (slight differences), rear brakes and handbrake, seats.
When it comes to body panels, only thing that comes close to fitting is the laurel, (think laurfiro). Essentially the laurel is the same as a cefiro, except they have a different body shell. But unlike the s13 silvia/180sx, the doors are not the same so you have problems getting the laurel guards to line up with the cefiro doors (they rub and the body lines don't match).
R32 front end?
Dont the ceffie and 32 share the same chassis
Cef's don't have the same chassis as anything except for laurels. There are similarities in certain parts, but like I said before you'll need conversion guards, custom head light mounts among other things.
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
