Hey,
i have a r32 gtr with a r33 rb26 thats fully worked that was rebuilt no more then 20 thousand ks ago.
i was driving it home 2 days ago and just as i drove in my drive way it started making a ticking/knocking noise.
does this sound like a spun bearing??
if so what could have caused this so soon after a rebuild? i got it compression tested 2 weeks ago and came back perfect then this happens??
my race bred sounds like a tractor...
http://au.youtube.com/watch?v=Nwp-Cl0Pq3o
Hey,
So.....who built it? What is done to it? Possibilities of failure are semi endless, incorrect assembly, incorrect clearances, losing oil pressure etc. Need to pull it down to have a look.
when u take the engine out, take off the head and throw the entire bottom end straight into the tip because pretty much none of it will be salvagable with that load a knocking
Sounds horribly like a spun bearing alright. Had one myself not long ago. I'm happy to come and have a listen close up just to confirm it if you like, I'm in coorparoo, but don't drive the thing over. Don't drive it at all. Send me a PM and I'll be happy to come and have a look.
Andrew
Did you follow the run in procedure set by the mechanic?
Run in?
meh, bed it on the dyno, tune it up. If its put together right thats all it should need
Either way, its beyond dead. crank and everything no doubt to the recycling mill :P
and ye, endless possibilities as to what could have killed it. The list is long
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
