Hey,
i have a r32 gtr with a r33 rb26 thats fully worked that was rebuilt no more then 20 thousand ks ago.
i was driving it home 2 days ago and just as i drove in my drive way it started making a ticking/knocking noise.
does this sound like a spun bearing??
if so what could have caused this so soon after a rebuild? i got it compression tested 2 weeks ago and came back perfect then this happens??
my race bred sounds like a tractor...
http://au.youtube.com/watch?v=Nwp-Cl0Pq3o
Hey,
So.....who built it? What is done to it? Possibilities of failure are semi endless, incorrect assembly, incorrect clearances, losing oil pressure etc. Need to pull it down to have a look.
when u take the engine out, take off the head and throw the entire bottom end straight into the tip because pretty much none of it will be salvagable with that load a knocking
Sounds horribly like a spun bearing alright. Had one myself not long ago. I'm happy to come and have a listen close up just to confirm it if you like, I'm in coorparoo, but don't drive the thing over. Don't drive it at all. Send me a PM and I'll be happy to come and have a look.
Andrew
Did you follow the run in procedure set by the mechanic?
Run in?
meh, bed it on the dyno, tune it up. If its put together right thats all it should need
Either way, its beyond dead. crank and everything no doubt to the recycling mill :P
and ye, endless possibilities as to what could have killed it. The list is long
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
