Strange Problem
Januss
 Share
Hey guys,
Theres this weird thing that happens to my car at stops/when its idling... it does burst of small revs like 250rpms .. kinda like a cough (the car shakes abit). It happens approx. once every 10 seconds. Should i be worried? or is this normal? thanks
Worried no, do something about it yes.
Could be the AAC Valve (very common cause of idle issues) clean it and see.
Could be the AFM, clean it and see.
Once those are clean you can try resetting your ECU, which is a good thing to do from time to time anyway.
Could be a small vacuum leak somewhere, worry about the first two in that order before this.
Are there any other issues along the rev range?
You don't have the aircon on when this happens do you?
See how you go and let us know.
Cheers
this started happening to my car not long ago
and now i have a huge problem the car is misfiring. coil packs have just recently been changed too. perhaps my spark plugs are worn i will buy a new set this weekend and test this out. i will also put the old coil packs in one at a time to see if one of the new coils are gone. they are obviously still under warranty but who knows. in the meantime my car is running like complete shit. slow, shaking, sounds like a wrx too.
Drew do some searching around, also try not to hijack this thread lol, but your issue could be one of the ones on my list. Could also be a crank angle sensor.
Test the stuff on the list and see how you go.
Let us know...
hijack? lol. im telling the guy im experiencing the same problem whats the point in starting a new thread.
in response
iv done a full engine diagnostic test with a laptop. cylinders are fine. for some reason the car is running very lean. i richened the AFR ratios and the missing seems to stop. i also did a fuel pump road test however none of these problems brought back any answers.
next i will put some cheap spark plugs in. if this doesnt fix it (one of the spark plugs could be worn) i will replace each new coil pack with my old coil packs to see if one of my new coils are stuffed.
it is "not" the aac valve this is clean. the AFM is brand new. i also put in another ECU and the same problem occured so its not computer related. it "may" be an air leak somewhere in a gasket. this is where i will look next after the coils and spark plugs.
well i seem to have two problems
AAV valve broken. turning idle set screw completely in and out changed nothing. and unplugging connectors doesnt change anything either so its either blown or faulty.
i will clean it out tomorrow to see if it revs a little cleaner
my bov is also leaking somehow. i blocked it off completely and the idle problem stopped.
need to buy a new plumb back or second hand stock one.
problem wasnt spark plugs or coil packs.
Edited by DrewII
Tested the problem with air conditioning on/off, i dont think it effects the frequency of the "burst of revs". Only seems to happen on idle.
My R33 is an NA (think this should cancel any issues relating to turbos). Ermm, got the spark plugs changed not too long ago, should not be the problm. Havent quite got arround to cleaning the AAC valve yet tho. Anyway, GL DrewII u seem to have a real problem there.
i have cleaned my AAC valve out
it was very filthy. the DIY AAC Valve guide in the DIY section was extremely easy to do.
the car is still sounding like a WRX so i can't tell completely what cleaning the valve has done. would have done more good than bad.
however im getting a brand new GFB Plumback bov installed so i will let you guys know an update after the new valve has been put on.
my problem is 90% bov 10% AAC valve so i should be sweet after the new bov is put on. fingers crossed.
its a normal skyline thing..u'll get use to it...
ive also got atmo greddy adjustable bov..and a atmo bov WOULD cause bad idle...
mine is set-up to hard setting..to prevent roughish idle...
the last thing u can do is take off ur idle air control valve..
spray it down wit carby/throttle-body cleaner..wipe off all the carbon..
and put it back on..
also adjust the screw on the side..will adjust ur idle..either up or down...so yeah...
just letting u no :P
its been happening to me also, my car after warmed up ussually idles at approx. 600 - 800rpm, then after sitting there for about 5 - 10mins, drops to 450 - 500rpms for a few seconds at that time the car shakes abit aswell.... HELP??
Hey guys,
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
