1990 Nissan skyline r32 gts4, 115,000km
RB20DET
Manual, heavy-duty clutch
Aftermarket pedals and gear knob
Factory LSD's front and rear
3in exhaust, 4in tip
4WD
4 wheel steering
digital climate control
Air conditioning
ABS
Power windows, mirrors
Tidy interior, VGC carpet and seats
Stock spoiler (with brake light)
Aftermarket 17inch rims
Vented fibreglass gaurds
Side skirts, stock front and rear bars (all in excellent condition)
Well looked after motor, dash has a couple of heat welts, but in otherwise very good condition, body has no damage, all panels very straight
the car is currently uncomplied, but has all adr seat belts and side intrusion bars etc to be complied. (it was imported under 15yo rule)
will sell uncomplied for $9500 ono (it will cost $400 to get it complied)
complied $12000 ono
registered $13500 ono
the spoiler, and tail light covers are yet to be painted. the car does come with skirts and pods, which are yet to be painted. does include indicators
Edited by sebastion
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/
RB20DET
4WD
4 wheel steering
Air conditioning
ABS
complied $12000 ono
Hi, I can't quite follow your maths :
You say that the price is $9,500 uncomplied, and that compliance costs $400, that comes to $9,900 and not your $12,000 figure ?
Unless I'm missing understanding something here ....
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/#findComment-4333114
+ ur forgetting the cost for other things... car trailer, time, car to tow it (as we live a fair way from an engineer). the idea is that there is a fair price is arranged for what is done to the car...
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/#findComment-4335051
  • 3 weeks later...
hey guys, here are some new pics. this is a nice car, mechanically a1, body's in great condition, brakes are beaut and handles very very well. come grab a bargin. I will also make a deal if someone wants it registered, and pays for the compliance and rego straight up and they will receive the car for a discounted price
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/#findComment-4382033
How about a straight out swap for a r33gtst ? But will need it complied and registered before the swap
sorry mate, I dont have the money to do the compliance and rego, if I did it would be done by now. thanks
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/#findComment-4382184
  • 6 months later...
how about 7k. im trucking to perth which aint cheap..
no price is firm, dont care if you live on the other side of the planet sorry... we had a bloke from america buy this (for $9000 US) but he thought it was up to us to organise shipping etc, and it was a bloody pain in the arse, so no shipping... these are not going down in price, and we are quite happy to hang onto it for as long as need be.
cheers
https://www.sau.com.au/forums/topic/249850-1990-r32-gts4/#findComment-4781453
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
