of course the car is going to go around corners faster. It has 4 huge tyres compared to the bikes skinny two.
...then u have the massive advantage of power to weight, my previous bike was lightened to 166kg with mods which took it to 173.5rwhp! best et was only 10.2s which isnt much - being a bike the laws of physics wont keep that front wheel down.
just think what a gtr will run with the same power weight ratio
the R35 GTR must be absolutely amazing
the brakes, amazing.
the bike in this instance was a good fair choice, just the extra massive breaks from the GTr, and its stability thru the corners, kept it up and in front.
would like to see the comparison 1 half-hour later after they have run the lap 3 times...... would be slightly closer than 3secs but not by much.
GTR must be awesome. enough said. the bike was ridden well, cple corners I saw he was hesitant with the car in front of him so I really reckon 2 more laps and the bike rider would be more comfortable and even more "committed" as they were saying.
nice find, thanks for that.
Thanks for the post....great vid
Looks like you have an aftermarket exhaust on your M3 there mate...
What did you go for? Did you eliminate that raspy note in the mid rev range?
I've been listening to all of the clips on klangford, but there isn't one that does it for me :D
Have you taken any video clips of yours? :D
Or, another way to think about that last bit:
Think what a GT-R will owe you to have the same power to weight ratio... :happy:
true, cars are expensive if ur chasing hp!
u can spend 10k on a 05 model jap bike and it will pull low 10's - at the riders discretion...i stopped riding this yr due to the danger factor as a few of my friends have had life changing accidents so i think the extra money spent on a fast gtr is well worth it
needless to say ive kept my leathers, tyrewarmers, stands etc just incase :-)
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
