haha Ash, thats why I found people buying SSD's and putting games on spindle drives to be complete idiots!!
one of my workmates got an OCZ Ibis drive today with the propietary interface (uses a seperate PCI-E card which is included), initial results look quite promising, loaded Win7 Ent x64 even quicker than striped Velociraptors or a Vertex 2!
That said, it's still 800 bucks on a freaking drive!
I think my SSD is starting to die, windows would freeze up randomly during start up & the HDD active light on my case will be permantly on & its not my other drives since it has no noise.
It is one of the 1st gen SSDs without TRIM support that I had for about 3 or so years.
FML I can't afford another one atm after I just below tons of $$$ on fixing up the car's cooling system... :(
So. Gonna upgrade soon:
Core i5 2500K (not overclocking though)
GA-P67X-UD3R
8Gb RAM (prolly some decent Corsair 1600mhz) (2x4Gb)
Asus CU II 570. Was looking at the 6970 but I'm swinging back to the CU II.
Currently running C2D E8500 + 4870 512Mb, and it's pretty fine for almost everything I throw at it. Running TRUE on the CPU to keep it cool and QUIET, and the TRAD2 on the 4870 (plus 2x 92mm fans, again, cool and quiet). Biggest thing is quiet. If anyone can suggest why a 6970 will be quieter and cooler than a 570 I'll listen :)
Suggestions? Don't wanna blow the bank, got major service on the liner to do. Got all the HDDs I need, etc.
GA-P67X-UD3R
Pretty similar setup you are running to what i have. Except i have a 5850 TopCU - it still makes mince meat of all games.
I'd suggest holding out to be honest. The next update to architecture is due in 6 months or so
i5 will also be dead not soon after that if memory serves me correct and hence you'd be better off going i7 2600k if you wanted to update, least you have an upgrade path.
GA-P67X-UD3R
Don't get p67. Z68 is about to come out. (I already have one as some stores are already supplying). So I'd get a ga-z68x-ud3r.
And go i7 2600 if u like however if your REALLY penny PINCHING go i5 2500. Either way both sandy bridges use 1155 socket.
But for the minor extra cost. U can get the 2600k and just up multiplier to 40-45x. Done. Safe OC. 30% increase in performance.
I personally would wait for next gen of cards. Gtx590 and 6990 are the end of this gen if you follow previous gens framework. (dual gpu, single slot have been end of gen usually)
Ram is fine. 8th more than enough. 1600. Get something at 1.5v if you can. Not too vital.
Would you consider a small SSd just for windows etc? Really speeds things up lol.
What PSU u gonna use?
Also I personally wouldnt wait for the next architecture change. The VERY next change is to IVY BRIDGE. Wich still uses 1155 socket. So no point waiting.
Next socket change is LGA2011 (as it's called so far. Might change) but it will be same price point as the 980x etc are now. Be prepared to pay alot more. 1000$ etc.
Edited by ShiftyTys
z68 is only useful if you are going to use Quick Sync. Were I to upgrade (happy with the i5 I have, ill just overclock for now), I'd be all over P67 + NF200 (for teh SLI)
Small SSD + data on spindle drives are impractical and self defeating for gaming for obvious reasons. I'd be inclined to get a 240 gig SSD if anything other than Raptors.
There is no real reason to go for a 2600 if you're gaming and not running a bunch of multithreaded workstation apps (hyperthreading being the main difference); the price / performance ratio drops right off between the 2500 and the 2600 (2600 is still great value though!) Don't bother with a multiplier unlocked CPU if not overclocking though lol.
The dual GPU cards are a waste of time and for those who are scared of SLI which is faster for the same price or at times even less. I haven't had any issues at all with mine, despite a lot of naysayers still being convinced things still are like they were during the time of the 8xxx series.
AFAIK, LGA2011 will be the uber expensive 'enthusiast' chipset and processors (given Intel's usual "tick tock" product releases). Overpriced to the max.
Go for more RAM speed over latency (I'm a Gskill fan myself), most people I know myself included are running 8 gig these days.
z68 is out. And has more features. SSd caching efi bios unlocked overclocking FSB overclocking. AND heaps of stability improvements over p67 (I know because I went through 4 p67 gigabyte boards that ALL had power cycling on boot and reset issues.
While waiting for my RMA to come through. Again. Z68 came out. So far. Zero issues.
I won't use SSd caching or prob even the efi bios. But it seems silly to me you would buy something gigabyte isn't even making anymore. and that other manufacturers also had heaps of issues on (asus had random bsod) esspecially at the same price.
Edited by ShiftyTys
Was looking at Antec Truepower 750W. Running a Basiq 550 at the moment; always had a good run with Antec.
Was half-toying with a 60Gb Vertex 2 just for OS and applications; I'll install all my games and shit on my 2Tb WD Black. I won't be overclocking; I just wanna put it in the case, have it run, and be cool and quiet (hence the extra ~250 on cooling for GPU and CPU currently in my PC), but the 2500K is $10 more than the 2500 so meh.
Image below for what I was thinking (PCCaseGear):
Hadn't 100% decided on RAM yet, not too fussed even if I get 1600. ~$150 for 2x4Gb sounds about right.
Plans might actually be going on back shelf at the mo; working out what's more important, new PC when mine works fine enough, or trip to Europe with the missus and her not having the shits with me. Sliding towards the second... Not like I have all the time in the world to game anymore :(
You dont need a 750w PSU for that GPU or setup IMO.
Get a Corsair HX650 or similar. No need for bigger PSU and you wanna aim for the sweet spot anyway.
I've used Corsairs in all my builds and my own runs a 650 and has 24x7 for 3.5 years now almost :)
Are those Corsairs modular? That's my biggest tick in the box; Got an Antec P180 case, and thoroughly enjoying using as little cabling as possible :P
EDIT::
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_354&products_id=12918
oh goodie, modular!
And yeah, I knew 750 was a bit over the top... Apparently I'll be fine with the 550 but I'll keep it with the older components and make it a spare box :)
http://www.antec.outervision.com/
I run SLI and 4 drives on a 700w lol, though I'll likely up it to an 850 just to be on the safe side
I got an 850 to be safe lol. Hx850 modular corsair.
Running 2tb caviar black. 2 tb samsung, 1tb WD, 120gb SSd. gtx285 (takes 2x6 pins for power). Bluray rom/DVD burner. And an OC CPU.
Oh yeh. Running 3 x 23cm fans and a 12cm fan. And both massive fans (12cm and 14cm) for my CPU cooler. Love my HAF932 and Noctua d14. :)
But yeah. I wanted to be completely safe and future system proof so I went the 850. Plus I was overclocking so I'd rather be safe. Too many issues caused by a shonky psu.
Hmm, Why not,
Case: Lian Li X-900
Motherboard: MSI P67 Big Bang Marshal B3
CPU & CPU Cooler: i5 2500K @ 4Ghz, Cooled with a CM V6GT
RAM: 8GB Corsair Dominator GT
Monitor: 2 x dell U3011, Mmmm Dual 30" goodness
Graphics Card: 2 x Gainward GTX 580
HDD(s): Corsair Force Series 120GB + 18TB on my server
OS Used: Windows 7 Ultimate
Peripherals: : Logitech G15 & G9x
Cost me a good 6ish K, wishing I had saved it up for the car (Didn't have it at the time) :angry:
I think it's time to sell it off.
EDIT: Like k1netic I know a LOT more about PC's then cars, didn't know this place had a PC section lol.
That's not alot of pc for 6k lol. I'm assuming a good 4k went towards the 2 monitors and 18tb worth of storage lol.
Monitors cost about 2.6K alone and another 1.3K for the 2 x 580's, that's pretty much where all the money went too. :thumbsup:
Already had the 18TB worth of HDD's, have been building it up over the past year.
Edited by Converge
Lol. Nice. Bloody expensive monitors :O
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
