Manage to swap my 4 month old 1/2 dying WD green drive for a new one at MSY.
Whole process went much smoother than I originally thought, after all the "MSY refund horror stories" I kept on hearing, got me all prepared for the possibility of a lengthy argument for nothing.
Just walked in with the drive, told them the problem & they just offered to replace it on the spot without even bother to test it or anything.
Now I just need to buy some external drives to back up my 1.5 TB anime collection.
  • 3 weeks later...
i have found that the windforce cards aren't much chop for SLI, was awesome when I had 1x GTX 460 though.
Might go MSI for the 670, only because they always seem to clock a bit harder than the Gigabyte for much the same price, but time will tell.
  • 1 month later...
CORRECT!
Start from a fresh install, clean it up, install all the apps you want and configure it all - Then image that. I always remove a bucket load of stuff from Windows that I don't want, different for other users perhaps.
Then it'll always be clean every time you ship it over (do it once every 6 months, you'd be surprised how much improvement it can make).
I guess i was more interested if that was a good price and quality SDD and big enough size?
sorry - could have worded it better.
But yes, idea was to copy data off that I want to keep - download all of the apps I need to a external drive, reinstall errytinks then use all of the 1tb OS drive for storage.
Jas I thought it was ok and bought 1 as well Intel have a very good reputation for fast SSD and for that they put a premium on their drives
I will be coming from a 64gb patriot pyro as my is drive I'm sure I paid about $125 for it
But due to the install size of windows 7 64bit and few other programs I couldn't keep bf3 on it, this will cure what ails me ;)
I've higlighted sustained in the intel stats, the Kingston says 535 but that is proberly burst either was both would be good upgrade options over a platter HDD
Intel
Technical Specifications (330 Series):
  • Model Name: Intel® Solid-State Drive 330 Series
  • Capacity: 120GB
  • NAND Flash Memory 25nm Intel NAND Flash Memory Multi-Level Cell (MLC)
  • Sustained Sequential Reads up to: 500 MB/s
  • Sustained Sequential Writes up to: 450 MB/s
  • Random I/O Operations per
  • Second (4KB IOPS)
  • Reads up to: 22,500 IOPS
  • Writes up to: 33,000 IOPS
  • Interface SATA 6Gb/s, compatible with SATA 3Gb/s
  • Form Factor, Height and Weight
  • Form Factor Height / Weight
  • 2.5 inch 9.5mm / up to 80 grams
  • Life Expectancy: 1.2 million hours Mean Time Between Failures (MTBF)
  • Power Consumption Active: 850 mW Typical
  • Power Consumption Idle: 600 mW Typical
  • Operating Temperature 0°C to 70°C
Kingston
Product Specifications
Form factor: 2.5"
Interface: SATA Rev 3.0 (6Gb/s) , SATA Rev 2.0 (3Gb/s)
Sequential reads
SATA Rev. 3.0: 535MB/s
SATA Rev. 2.0: 280MB/s
Sustained Random 4k Read/Write
60GB: 12,000/47,000 IOPS
90GB: 20,000/47,000 IOPS
120GB: 20,000/44,000 IOPS
240GB: 36,000/43,000 IOPS
480GB: 43,000/30,000 IOPS
Max Random 4k Read/Write
60GB: 85,000/60,000 IOPS
90GB: 85,000/57,000 IOPS
120GB: 85,000/55,000 IOPS
240GB: 85,000/43,000 IOPS
480GB: 75,000/34,000 IOPS
Power Consumption:
0.565 W (TYP) Idle / 1.795 W (TYP) Read / 3.230 W (TYP) Write
Storage Temperature:
-40degree ~ 85degree
Operating Temperature:
0degree~70degree
Dimensions:
69.85 x 100 x 9.5mm
Weight:
115 grams
Vibration Operating:
2.17G
Vibration Non-Operating:
20G
MTBF:
1,000,000 Hrs
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
