in that socket 1155 they make i5 and i7 to suit
also the i7 has 2mb more cache and 100mhz faster i have just done a simple OC and im pushing 4ghz on the 1333 sniper ram more than enough to play BF3 once they polish the game more i should get a few more frames
ati cards always have driver / game issues, which is why I avoid and don't reccomend them to people (apart for use in HTPC or other non gaming).
TBH if you're sticking with 7200rpm drives in a new build you should damn well make sure that you're buying the fastest one with the most cache etc you can afford. Got me stumped how people are willing to lash out on processors etc but leave their drives as the bottleneck! (unless your budget really is that tight)
EDIT: furthermore to this, we are starting to exclusively rollout Vertex 2 spec SSDs in the next batches of workstations we are getting at work because it's become THAT much of a bottleneck.
Edited by bozodos
Hmmm i have run ATi since my 9800pro i danced with the devil for 4days while owning a 6800gtx but it didn't perform as good as the top ATi back then if i recall was the x800xt pe i ended up with a x850xt pe 1gb and was very happy i have always been happy with the cards games and anything i throw it it
i don't really OC my gfx cards or my systems by much
had a lot of bad times with my 4830 all driver related, did overclock the shit out of it in the end though hahaha.
Catalyst always seems to break shit; we run ATi in our Dell Optiplex fleet due to there being a lack of a Nvidia option, and the only issues we have are again drivers. Kinda fanboyish I know, but I've never had a problem with compatability from owning a TNT2 onwards with Nvidia cards.
yeah i had a TNT2 that was great i hod the old pci version when AGP just came out used to play sof2 with it and get all of 20fps
i keep my drivers updated too
and i don't always buy games when they're at there peak price
i may preorder bf3 however
So I'm going to get a i7 2600k along with a Z68 mobo of some kind just wondering what is a good aftermarket cooler for it?
I currently have a Zalman for my Q6600, seem to work fine.
Also what is currently the best bang for buck SSD out? Looking at the $250 - $350 mark. Only need 60Gb or so as it is only to be a OS drive. I'm getting a 600GB raptor for my games & all my old HDDs will carry over as storage drives.
My current gen 1 SSD is starting to die I think (randomly windows will freeze up & upon reboot, windows disk checker will pick up & fix some random corrupted files on the main OS drive).
SNIP
mobo: gigabyte Gigabyte GA-Z68MA-D2H-B3 $139 (you will want to know how many slots you want to use if using dual gfx you may loose the other pcie slot)
CPU: i7 2600 $285
Snip
i5 2500k will be more than enough for your intended purpose
I wouldnt bother with a locked 2600, an overclocked 2500k will surpass it with ease, as well as being about $75 cheaper.
With the money you save you can also get yourself a decent CPU cooler, or spend more on a GFX card :)
4.2ghz here with a 2500k and stock cooler :)
Main benefit of i7 is multiple threads per core but they don't really come into play with games (yet)
i am currently running 4.3ghz stock cooler and have read people getting 4.6ghz on a Coolmaster 212+ heatsink and fan combo
i can get 8.9sec in super pi 1.6 and just idling i get about 40deg and about 70 on 100% load
would be interested to see your superPI score so clean
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
