Manage to swap my 4 month old 1/2 dying WD green drive for a new one at MSY.
Whole process went much smoother than I originally thought, after all the "MSY refund horror stories" I kept on hearing, got me all prepared for the possibility of a lengthy argument for nothing.
Just walked in with the drive, told them the problem & they just offered to replace it on the spot without even bother to test it or anything.
Now I just need to buy some external drives to back up my 1.5 TB anime collection.
  • 3 weeks later...
i have found that the windforce cards aren't much chop for SLI, was awesome when I had 1x GTX 460 though.
Might go MSI for the 670, only because they always seem to clock a bit harder than the Gigabyte for much the same price, but time will tell.
  • 1 month later...
CORRECT!
Start from a fresh install, clean it up, install all the apps you want and configure it all - Then image that. I always remove a bucket load of stuff from Windows that I don't want, different for other users perhaps.
Then it'll always be clean every time you ship it over (do it once every 6 months, you'd be surprised how much improvement it can make).
I guess i was more interested if that was a good price and quality SDD and big enough size?
sorry - could have worded it better.
But yes, idea was to copy data off that I want to keep - download all of the apps I need to a external drive, reinstall errytinks then use all of the 1tb OS drive for storage.
Jas I thought it was ok and bought 1 as well Intel have a very good reputation for fast SSD and for that they put a premium on their drives
I will be coming from a 64gb patriot pyro as my is drive I'm sure I paid about $125 for it
But due to the install size of windows 7 64bit and few other programs I couldn't keep bf3 on it, this will cure what ails me ;)
I've higlighted sustained in the intel stats, the Kingston says 535 but that is proberly burst either was both would be good upgrade options over a platter HDD
Intel
Technical Specifications (330 Series):
  • Model Name: Intel® Solid-State Drive 330 Series
  • Capacity: 120GB
  • NAND Flash Memory 25nm Intel NAND Flash Memory Multi-Level Cell (MLC)
  • Sustained Sequential Reads up to: 500 MB/s
  • Sustained Sequential Writes up to: 450 MB/s
  • Random I/O Operations per
  • Second (4KB IOPS)
  • Reads up to: 22,500 IOPS
  • Writes up to: 33,000 IOPS
  • Interface SATA 6Gb/s, compatible with SATA 3Gb/s
  • Form Factor, Height and Weight
  • Form Factor Height / Weight
  • 2.5 inch 9.5mm / up to 80 grams
  • Life Expectancy: 1.2 million hours Mean Time Between Failures (MTBF)
  • Power Consumption Active: 850 mW Typical
  • Power Consumption Idle: 600 mW Typical
  • Operating Temperature 0°C to 70°C
Kingston
Product Specifications
Form factor: 2.5"
Interface: SATA Rev 3.0 (6Gb/s) , SATA Rev 2.0 (3Gb/s)
Sequential reads
SATA Rev. 3.0: 535MB/s
SATA Rev. 2.0: 280MB/s
Sustained Random 4k Read/Write
60GB: 12,000/47,000 IOPS
90GB: 20,000/47,000 IOPS
120GB: 20,000/44,000 IOPS
240GB: 36,000/43,000 IOPS
480GB: 43,000/30,000 IOPS
Max Random 4k Read/Write
60GB: 85,000/60,000 IOPS
90GB: 85,000/57,000 IOPS
120GB: 85,000/55,000 IOPS
240GB: 85,000/43,000 IOPS
480GB: 75,000/34,000 IOPS
Power Consumption:
0.565 W (TYP) Idle / 1.795 W (TYP) Read / 3.230 W (TYP) Write
Storage Temperature:
-40degree ~ 85degree
Operating Temperature:
0degree~70degree
Dimensions:
69.85 x 100 x 9.5mm
Weight:
115 grams
Vibration Operating:
2.17G
Vibration Non-Operating:
20G
MTBF:
1,000,000 Hrs
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
