Gotta say my Sandisk 240gb SSD is f**king phenominal.
Only takes a few seconds and I'm already bashing in my password, couple seconds later it's fully loaded the desktop.
It's a fresh install with a whole heap of re-installations of all my applications... So I'm yet to trim all the shitty background processes, applications and the boot process so it'll be even snappier once that's done. Even with 3 games, O/S and all my software loaded I've still got roughtly 150GB left. It'll be down to 100GB once i put Skyrim & a couple other games on but by the gods it's impressive over my RAID0 mech drive array (which in its own rights was very impressive).
I'll definatly take a mirror of it once it the O/S is all trimmed down so I can buzz it whenever i want.
Boot speed isn't even the best part!
I just love how with an SSD pretty much everything I do happens at an instant. Open Outlook, BAM! Open a browser, BAM! New tab, BAM! Games load so much faster. Battlefield 3 is a great example. You're into a game within 20 seconds.
There is a group of people who knock SSDs cause "why do I care if my machine boots 20 seconds faster?" but that's not telling the whole story. PCs with SSDs just do everything almost instantly.
I love my SSDs *cuddle*
and quieter also :D
My WD Blacks are quiet as? I can't hear them at all inside the case - cant really complain there. Plus the fans drown anything else out easily enough.
I have 4 drives in my case, and 4-5 drives in my server, no noise :)
Yeah true and a gfx card fan noise will cover any other ambient noise
I will be putting my old 60gb SSD into a 10" Dell inspirion mini so will be good to see how well it works on mini PC's with Atom processors
I just put a cheapo OCZ Octane into my 6-7 year old Asus duo core. It's transformed it! Thing bloody flies now.
I don't have MS Orifice on my home PC. Got a work lappie & work PC that i can use that for... Although I might install word/excel only in the near future.
My 64GB used consists of:
Windows 7 64 Bit SP1 (fully updated now).
Firefox & Chrome Browsers
Starcraft 2
Battlefield 3
Nvidia GPU & ASUS sound card software
Steam (no games yet)
ASUS/Intel mobo suite/apps and full drivers etc
There is other miscellaneous shit like Fraps, Logitech mouse/keyboard software, uTorrent etc but it's all relatively tiny.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
