CPU is clockable, but you might want to update the graphics card.
We had talked a little while ago about massive price drops on the current range of high end cards as dx11 is due prob early next year in which case if you can hold out you could a $600 card now for close to half price. Could be worth the wait.
Only paid $40 for the 8600GT, there's no real point in buying more PC parts because I've nearly finished building my xbox 360 (plus I can play Crysis on medium in a decent resolution lol). I was going to get a 9600GT, but for the amount of games I'm playing on the PC these days there wasn't much point.
I currently have the Engine set on the video card to 600mhz, the Shader to 1250, and the RAM to 850, running nice and stable so far.
When it's time for a DX11 card I'll probably just build a new box and get rid of my laptop.
DX11 will be only coming 'in' 4-6 months after DX11 comes out before you can actually make use of it.
So that will be 2010. Hence i just grabbed a 4890 for now... sit on that till Q1 or Q2 in 2010, then upgrade again by which stage the initial 'release' prices will have fallen nicely and 2nd Gen cards will be coming out too
ATi are apparently on track for DX 11 with Win 7. So once ATi and nVidia have DX11 cards I'll get some new ones, nothing to do with DX11 they just happen to be the next gen of cards.
FYI the 8600 is a dog turd of a graphics card as it's memory bus is tiny so no matter how high you OC it's hobbled.
Edited by DivHunter
Ye, true Jacob - although im just gonna wait, dont need anything greater than a 4890 at present
^ the Sapphire one is a waste of $$.
Buy a standard one and it'll clock to 901mhz.
I have the PCS+ 950mhz and better cooling, ok so far but wont clock any higher, so i need to investigate how much voltage its running in the next day or two
Talking about GFX cards....
If you have OC'd your graffix card and you are using RivaTuner DONT UPDATE TO THE LATEST NVIDIA DRIVER.
Long story short the new driver is not supported by Riva Tuner as yet and the latest riva tuner is still close to a month away
So all my clocking of my 9800GTX has now gone :-(
There are some work arounds but generally they only change the fan settings under load NOT the OC itself.
Quite annoying really.
Hey guys,
Just wondering if you could give me some ideas for a new media PC i want to get going. Got a fancy new TV so i want to be able to record tv easily using webscheduler etc as well as browse the net and network the TV.
I'd like to get out of it as cheaply as possible but also want a computer that can run HD TV nicely and a few apps at once. Main things I want is -
- minimum 1Tb HD
- GFX card with HDMI/VGA output
- Dual TV tuner, preferably with one analogue tuner but not essential
- Plan on running windows 7 as an OS, and want fast start up time etc
Obviously i need a psu, mobo, cooling etc to support that stuff but i'm not too sure what i will need. Also a nice small case would be good as it will sit near the TV. Would you guys have any suggestions as to whether i'd be best looking at some second hand gear, or just get all new, and if so, whats the best to go for these days?
Did you try and OC the PCI Express bus?
you're lucky :D
I'm not willing to bet a HDD of data or similar on possible corruption setting it about 100Mhz, some people will when benching and using DICE and so on...
Especially not once i stick my raid0 setup together lol
I've had not problems with pushing it between 100-110 on my X38 mobo running X48 Rampage BIOS.
I've used the P5E and the Rampage Formula and they both can run 110 pretty easily however other boards don't like it at all and can also kill your cards. Especially non-grpahics cards in the PCI-e slots.
To give you an idea
E5200 - $90
500GB HDD - $70
4GB DDR2 - $60
Thermaltake VK81221N2 - $150
Tuner Card - $45
DVD-RW - $25
Mobo - $115
Total $555
So if they are charging $600 that's a pretty good price for that. Although I'm not sure how it would go playing HD stuff to be honest, and that is where everything is heading so IMO you'd might as well build for it as its not that much more
To give you an idea
E5200 - $90
500GB HDD - $70
4GB DDR2 - $60
Tuner Card - $45
DVD-RW - $25
Mobo - $115
Total $555
Thanks for the price comparison - they are some very competitive prices.
Regarding the HD, thats one of the reasons I thought I'd ask here - from what i've read, most modern budget systems are more than capable of HD stuff and anything more is overkill... any more thoughts on that?
Dude, you should be fine with Full HD content on that system. My current media pc is an old Athlon 64 3500+ with 2gb DDR400 ram. With an old 7900gtx graphics card. I can play full hd content no worries(1080p if only program running, and 720p with a few programs running). Bare in mind my system has been slimmed down considerably, but with the advantages of a faster and more effecient setup like yours, you shouldn't have any problems at all.
Best of luck
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
