passive cooling aint my thing (too many things to buy and no space), plus i like to overclock thank you very much.... it helps me test the limits of my computer before it blows :P
p.s, havent gotten my other res yet so the cool zip tied res will have to stay a little longer :D
think the only cheap thing in that system was the rad. little cheap POS, but it keeps my comp at about 40-50 degrees under full load, im pretty happy
keep a eye on the temps of that GTX 465 in a mid tower.
updated list of my gaming rig aswell as the server
Gaming rig
Case: Thermaltake Xaser Super tower with LCS
Motherboard: Gigabyte EP45-UD3L
CPU & CPU Cooler:Intel Q9400 2.66GHz
RAM: 4GB Kingston HyperX DDR2
Monitor: 2x Samsung 24" Dual linked
Graphics Card: XFX GTX 285 With Artic cooling GTX pro Leadtek GTX 470 with Artic cooling Accelero Xtreme Plus cooler
HDD(s): 1x Samsung 1.5TB 1x Samsung spinpoint 500GB Western Digital Green 1TB
OS Used: Visa Home premuim
Peripherals: Logitech G25,
Razer lycosa keyboard
Razer diamondback mouse
Razer eXactmat
LG DVD burner set to region 2 ( Japan region)
samsung DVD burner set to region 4 ( Australia)
Thermaltake toughpower 850W PSU
logitech 5.1 surround sound
eation 5110 UPS
Server
Case: Thermaltake M9D Mid-tower
Motherboard: Gigabye EP45T-UD3LR
CPU & CPU Cooler: intel celeron E3300 2.5GHz
RAM:2GB DDR3 RAM
Monitor: one of the 24" LCD's of my gaming rig
Graphics Card:Asus EN8400GS 512MB
HDD(s): 4x western digital 2TB Hard drives
OS Used: XP hom
Eaton Ellipse ASR M66780AL 1000VA 600W UPS
ugh gtx 465, send that shit back if you can - gtx 460 is faster, cheaper and uses a shitload less power
465 ended up being discontiued so I changed the order to a 460 :thumbsup:
that's a really nice build tbh, but why such a tiny case?
tossing up between SLI GTX 460 or a 570 for mine, will probably go SLI cause it's cheaper
I wanted something small to take to LANs as well. Was getting sick and tired carrying a mid tower, plus i've always wanted a small case from my last build which was 6 years ago.
The new GTX 560 is out, that could be a better option than the 460, plus your future proofing yourself for that bit longer.
argh what is it with people building flash rigs with bloody Caviar Green OS drives?!?!?1?! ARGH!@%#&%#$$#@^#*%#&*
I'm going to buy another WD Green drive (probably the 2TB one this time) :P
But I have a 64GB SSD as my main OS drive & a 7200rpm drive for my games.
since I started downloading 720p/1080p of everything... the old drives are filling up fast.
but that bit longer could only be a few months. i mean look at the GTX 280's released when? 2008/09? they are already been used as a reccomended spec card for Test drive unlimited 2 ( a game that doesnt really push the card that hard). and soon i imagine they will be used as a minnimum spec card.
and the way games/cards are going, youd probably need to upgrade every 2-3 years.
Edited by liger
I had thought about it, and for the 300 dollars on a 560, I could spend 100 bucks less and SLI the two 460's which ought to keep me going for up to 2 years (depending on games development).
I'd then either go to a x70 or an x80 depending.
That's fair enough George, I was referring to booting from a Caviar Green, having your swap file etc all on it.
I run Caviar Blacks in a RAID 0, and that's barely fast enough. Eventually I'll just stripe two Velociraptors and be selective about which games I install
Case: Antec 900
Cooling: Noctua CPU Cooler, 5+ Antec Case Fans
Motherboard: Gigabyte EP45T-UD3LR
CPU & CPU Cooler: Intel Q6600 @ 3.2GHz
RAM: 6GB Corsair XMS3 @1600Mhz 1.65v
Sound: Logitech Z-5500
Monitor: Acer 22"
Graphics Card: nVidia GTX285
Power: Antec 650W
HDD(s): 2 x Seagate 1TB + 1 WD 500GB and 1 Seagate 500GB
OS Used: Win7 Ultimate
Peripherals: Logitech G25 Wheel,
Logitech G15 LCD Keyboard,
Logitech G500 Mouse,
Logitech Extreme 3D Pro,
Razer eXactmat Control
what games you play with your G25
Hi Guys,
Thought I'd share with you guys my new PC after 6 years with a P4 Northwood. Specs are:
CPU: Intel i7 950 with stock HSF
Memory: 12Gb Corsair Vengeance DDR3 1600Mhz (3 x 4Gb)
Motherboard: Asus Rampage III Gene
Primary HDD: OCZ Vertex 2 E 120GB SSD
Data HDD: Western Digital WD1200FAEX 1Tb
Video Card: Leadtek GeForce GTX570
PSU: Corsair HX850
Optical: Pioneer BDR-206BK (BD burner)
Case: Lian Li PC-V354 Black
Hey guys,
How much would I be looking at if I just want to buy a motherboard, Intel i7 cpu, 12gb of DDR3 ram??
Currently I'm running a quad core 3.2ghz with 4gb ddr3 ram, 1gb gfx card (cant remember who makes it etc).
Plays BFBC2, Black Ops, Modern Warfare 2 etc all on full graphics with ease, but I'm just curious to see how much it would cost to upgrade?
Cheers :)
Bubba!
Now the point of me asking in here, is simply because I can not be bothered looking myself and would prefer someone else to do it for me :)
I brought my current PC setup from somewhere in Osborne Park about 12months ago. The cpu, motherboard, ram, graphics card and power supply set me back around $1000.
Which i7 socket?
Top of the range 1366 mobo still retails for over $200 (with more expensive mobos still costing $400 to $500), CPU is around $300 (950) & a 12Gb ram kit is around $200...
Why 12GB?! :blink:
I still have a 286 that still actually fully works :)
- Intel 80286 CPU
- 1MB ram
- 1.44MB 3.5' FDD
- 40MB HDD
- 14' CRT
- VGA Graphic card (don't know how many KBs in size - but can display 256 colours at 640x480 max)
- MS-DOS 5.0 with dos shell
- Panasonic Dot-matrix KX-P1180
3d mark that b****, oc it too, put a good heatsink on and you cna get to 700mhz+
Fark some decent setups getting about now...
Im gonna have to update soon i think just for bragging rights!
Although im SPEWING they stopped making 5850's, wish i had've known sooner as i would have grabbed 2x Asus TopCU cards, they are stonking OC'ers!
Will get some pics soon of case etc, its well due for some cleanings
haha because it's triple channel on the socket 1366, hence 6 or 12 gig.
IMO if you're going anything under i7 950, then Sandy Bridge is the go for sure, especially if you don't plan to SLI.
i7 2600k is the bomb atm
Yeah I know about the tri-channel thing, but I'm struggling to find any use for 12gig Ram unless his running multiple OSes at the same time?
I was reading about the sandy bridge before & it got my attention the "apparent" bug in their SATA I ports? Doesn't affect most people since they only have 1 or 2 HDDs (which they can just put on the SATA 2 ports) but since I have 6 atm (only stopped adding more since my case ran out of drive bays) I'm waiting for them to fix it before I look into building a new computer.
this is pretty awesome news, though possibly not news for some people
>>Sandy Bridge<<
with a new BIOS called UEFI (Unified Extensible Firmware Interface)
uefi2.jpg<<Click
im waiting for a new BIOS until i upgrade the above got me excited like Big Kev
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 馃槢
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
