Coolermaster HAF 932 case
Corsair 850w modular psu
Noctua d14 CPU cooler
8 gb gskill ripjaws 1600 8-8-8-24
Intel i7 2600k (oc to 4.5 ghz with no vcore change. Just multi - not finished ;) )
Gigabyte gtx285
Giganbyte ud5 mb
120gb ocz SSd 285mbps read/write
2tb caviar black (games)
2tb samsung green (media)
1tb caviar green for random (pr0n etc. )Rofl :P
SuperPi 1m = 7.6 secs.
26 degrees idle.
48 degrees max on burn-in test after 4 hours.
50 degree max on prime-95
Edited by ShiftyTys
nice overclock, pity you wasted it by putting your games on 5400rpm drives @_@
Do you know what a WD caviar black Hdd is? It's just the fastest spinning drive on the market. Forget raptor. Inneficient way to increase speed by rpm. Also you see the SSd there? Important games on there.
How is your Prime95 hotter than IBT? :ermm:
ITB will usually see 10 degrees more than Prime in every PC I've ever built from standard E5200 to overclocked everything!
Someone gimme 1800... I need to regeek myself. All i've done is build home/stocker PC's for friends the past 6 months.
Nothing fast or remotely interesting :(
Different days. In fact I was gonna say idle temps for the day, before the load temps in my post. But then I CBf. Lol
Yeh 1800 for my rig. Oc the 2600k is bliss.
My Setup
LAPTOP $699
BRAND: ASUS K52F
OS: Windows 7 Premium
CPU: Intel Core i3 370M, 2.4GHz
VGA: Intel Graphics Media Accelarator HD
DISPLAY: 15.6 HD/LED BL
HDD: 320GB
MEMORY: 3GB
GAMING COMPUTER $450 (Swap Meet Build)
BRAND: None
OS: Windows Vista Ultimate
CPU: AMD Athlon II x2 255 Processors (2 CPUs) 3.1GHz
VGA: NVIDIA GeForce GT 430
DISPLAY: Pioneer 50inch TV
HDD: 500GB
MEMORY: 2GB
For what part? :D
Plenty of parts that can be checked lol
Although i dont check my CPU anymore. It's run 4.2ghz or whatever daily for almost 3 years now, never got hot in the first 6 months and that was good enough for me.
Although i do make sure i clean it every 3-5 months from dust etc. And i do check the CPU after reseating the heatsink
  • 4 weeks later...
Would it be worth buying say a 60gb Solid State Hard Drive just to install Windows 7 on? And then run my games etc off another 7200rpm hard drive?
By doing this, will it effect games performance in a positive manner?
you'll see better boot times, but games won't really run any quicker.
I looked into it for mine, and thought "nah f**k that" and didn't have the cash for 2x VelociRaptors, so Caviar Blacks it was!
2x Velociraptors in RAID 0 will kick an average SSD and have al ot more space!
The PCI SSD's are still not as cheap as the 2nd gen SSD. They are line ball still even though they should be cheaper theoretically.
3rd Gen SSD's are coming out. I've been watching as I'm due to a refresh in the next 6 months and intel is due for another update in Q4 i believe.
So end of year will be good timing i think.
SSD wise - put the game(s) on it also. just having it on the OS is only boot time and sometimes load performance. However games do benefit from being on a SSD. No doubt about that
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
