Hey again,
Over the past couple of weeks, while surfing the net, I’ve seen numerous amounts of people asking about yellow headlights and how to restore them to factory fresh. I’ve even seen as far as people setting up group buys for $150+.
Now this really annoys me, as it’s a very simple process to do. Then you get people saying it’s really bad when they turn on their lights, so quickly come to the assumption it’s inside of the headlight. I guarantee 99% of the time it’s just on the outer surface.
This guide offers you guys a simple, cheap (talking about less than $10 here) yet equally effective solution. I’m talking no buffers, no special chemicals, no tricks.
Now, for those who don’t know, here’s a low down on why headlights turn yellow. It’s plastic! Simple. Like any plastic, as it ages the clarity disappears.
This really only happens on R33 and R34 Skyline’s due to the plastic housing headlight, unlike the R32 which is made of glass. Hence, this tut applies to all R33 and R34 Skylines.
Right:
Tools needed:
-Wet Sandpaper / Automotive sandpaper. You can pick this up at your local hardware store or auto paint supplier. You’ll need 1000, 1200, 1500 and 2000 grit. Just one of each will be more than sufficient.
-Car wax. (Just any reputable brand should do, or any you have lying around your house)
-Masking tape
-2x Pieces of cloth, preferably something not rough.
-Strong buffing arm
Step 1: Sandpaper / Preparation
Start by ripping considerable pieces of same paper (of each grit) and let them soak in a bucket of water for a good 20 minutes.
Whilst the sandpaper is softening now’s a good time to mask of the car. Now this is a very important part as you want to mask off nay part you don’t wish to sand. You can never be too careful or use too much masking tape.
HINT: Instead of masking your bonnet, have it open all the time, that way you can save time and don’t F*ck it up.
Step 2: Initial sanding
Start with the highest grit 1000 and start sanding the headlight. You should sand the headlight for a good 3-4 minutes on each grit. Now do you see the yellow particles you’re sanding off, yep that’s a good sign not just an illusion.
NOTE: When sanding you should only be sanding in one direction, i.e. left – right or up – down. This prevent swirls and deeper scratches.
Also while sanding always keep the sandpaper constantly wet to prevent clogging.
When finished, give it a wipe with some tissues. It should look like this a very dull finish.
Now your probably thinking at this stage “What the F have I done, it’s ruined. I’m going to kill that Chang guy” No no, don’t worry it’s all part of the process. Just keep reading.
Step 3: More sanding
Now after using 1000 grit slowly progress down, 1200, 1500, 2000 till it looks like (After final 2000 grit)
Step 4: Polishing
Now I’m sure like me, majority of you don’t have any special chemicals or buffers. Too expensive, too difficult, too lazy, too can’t be f’d
Anyway, get your polish that you’ve got and polish it like you would a car. But really get into in. I mean rub it hard. Use a lot of elbow grease.
Till it looks like this
NOTE: You should be polishing in a circular motion, as opposed to the sanding technique.
Use the second cloth to wipe away the wax as per normal. You should be waxing until you can’t feel your hand or about to pass out.
  • Like 1
good tut, I use plastic polish to the same affect, the problem I now have it that after sanding/polishing, we have taken off the UV protective coating so it will yellow and craze again faster. I'm yet to find a way to recoat them other that those 'skinz' which are clean and UV protective, but they cost a small fortune lol.
Finished product:
See your done four easy steps to restoring your headlights. Now before you tackle this, you should like me and take photos. It not only till you compare the before and after do you see the difference.
Before:
After:
Before:
After:
Before:
After:
Now you’re done. See, under $10 and you saved a considerable amount for your other mods. Although your arms have lost feeling by now, it’s well worth it. Don’t you agree?
It's sort of hard to depict the yellowness in photos. My headlights weren't as terrible as some out there but enough to see a yellow tinge.
None of the left unfortunately, as I thought the right one was worse and show a better before and after.
Edited by Chang
a great writeup,
meguiars plastic x will clear up the lenses a bit better then the deep crystal polish, but either will make a good noticable difference. The sanding is well worth the effort to smooth off the dulling caused by grit in the air whilst driving
alex
so i had a crack at it today, used meguiars plastiX & scratch X didnt really do much as i used it before and got alot off but headlight is still yellow (which im pretty sure is all in the inside now)
so gonna have to open up the headlight and do the same for the inside.
i used a orbital buffer/polisher as well.
good write up tho & applies to ppls headlights with slight yellowing/fogging.
keep rubbing and rubbing till no more yellow crap comes out on the rag, if headlights are still yellow then its all in the inside. thats how u can tell wehther its in or out
Edited by dori32
u ill probably find that ur headlights will go back to yellow after a short amount of time coz mine did wen i sanded n waxed them. there is a product i bought from the auto salon that i used on mine and it worked mint andthey r still perfectly clear. its called GLASSYLITE not sure where to get it but if u googe it u would find it. it cost me $20 and my lights hav been perfect for like a year now and it actually seals the lights so they dont go yellow again.
Hi Chang
Dude, thank you so much for this write up! I followed the instructions, except i used meguiars plastx to polish the lenses instead of normal polish. It looks brand new, simply amazing. Altogether it cost me $27 for plastx ,$5 for sand paper and $2.50 for polishing cloth!! Job took 1 hour, my arms also look like Arnold Swarzenegger's now!!
there is so much you can do before you realise its actually the inside that needs to be polished up, then you will have to take it to a specialist to open it up and clean it.
Yeah whatever!! Mine looks brand new, i'm happy. Specialist.....pfft!
Hi Chang
You better keep working out cause in 3 months you will be at it all over again... you have just successfully damaged your lights, wasted money time and energy. save yourself seal em with glassylite now!
Oh forgot about this thread.
Hi Chang
Your welcome mate, glad I could help.
Dude, what crawled up your ass. My headlights have been out in the Summer for 2 months now. Still looking as new as ever.
A regular polish then wax will keep it going.
Keep your negitave comments to yourself.
I like to use Novus plastic polish ! Realy easy to use you can check it out on youtube ! the full 3set kit costs about 15$usd on ebay !
http://www.novuspolish.com/
I also did my r33 headlights using this guide I googled up hope this helps some one out !
http://www.mkiv.com/techarticles/headlights/index.html
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
