hi All i have a problem at the moment i have the police trying to tell me my r32 gts is over power to weight ratio to drive on p's with i disagree with and will be fighting in court to help my arguement i am looking for offical nissan approved r32 gts skyline spec with powere weght and gea ratios in it or i am after a manual for the car if some one knowas were i get can theses specs otr this manul form it would be a great help if u wish to contract me u can do so via phone my nuber is 0434787620 or emial [email protected] any help i anc get will be greatly appricated
Regards matt
https://www.sau.com.au/forums/topic/249940-r32-skyline/
Regards matt
Hey buddy, Unfortunately i dont have the info you want, but if you dont get any help on this thread, try posting on general automotive discussion part of the forum, more traffic flow if you know what i mean!!!
Good luck
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4334370
What state you from? Not clued up on all other states laws but I'd imagine an R32 GTS should be legal
You can get the service manual for all engines fitted to R32's here: http://www.importworkshop.com/nissanskyline.html
Don't know where you can get confirmation of the official weight as manuals for the GTS versions are hard (impossible?) to find... Couldn't you just get the car weighed?
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4334927
Per Redbook:
http://www.redbook.com.au/used-cars/detail...id=11D96DE42547
116kw... your rego sticker will specify the weight of the vehicle... you can do the math.
dont believe the rego sticker, it is usually way off from car specifications.
Not sure if it would help but;
1988-1989 GTST (series 1) weigh's around 1280kg
1990-1993 GTST (series 2) weigh around the 1350kg mark.
GTS should be lighter as it would be missing all the turbo stuff and smaller brakes etc.
However the power/weight ratio is using the unladen weight of the car. Ie. no fluids etc.
Any car information you will find will only state the kerb weight...
Cop told me the vicroads sticker weight is the unladen weight (which read 1250kg on my GTST) but all my r32 friends have different weight values on the sticker..
Hope that helps someway..
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4335475
for his purposes the weight per rego will surely be considered reliable as will redbook for the power figure.
So if it did go to a court case he has information that is reliable and I am sure it will confirm the car is under the power to weight ratio... If it isn't then you would not be allowed to drive pretty much any car, except maybe some 800cc Diahatsu
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4335782
  • 1 month later...
i had it weighied it cam in at 1400 then dynoed ad it dymoyed 99kws at the rears witch dose not match any of the specs i have found on sites withc is real frustrating casue unless there actualy offical they dont hold up in a court of law witch relay sucks
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4422110
well does 99kw : 1400kg comply with regulations?
shesh........1400Kg thats heavy!
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4422342
1. You should learn to spell..
2. Surely if you took documentation that shows your car has been weighed and dynoed and complies within their standards then that is submisible in court.. If not then throw it back in their face, and inform the judge that you wish for the prosecutor to prove that it doesn't comply
https://www.sau.com.au/forums/topic/249940-r32-skyline/#findComment-4423793
